03-19-2019, 03:17 AM | #1 |
625
Rep 1,333
New 3 hard ride without adaptive
Test drive confirmed to me the ride is pretty harsh on U.K. roads. Test reports seem to say adaptive suspension is better.
03-19-2019, 03:24 AM | #2 |
454
Rep 1,373
Been like that since F30/F32
Best option you can get on a car for £550 at the time which nobody ever specced up. It should be standard instead of the crap they make standard. |
03-19-2019, 03:39 AM | #3 |
1867
Rep 13,043
Drives: BMW M340I G20
It's part of the M Sport + package, and as per the F3# an option worth ticking.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
03-19-2019, 03:52 AM | #4 |
2876
Rep 3,966
I've got it on my F36 which is on 19"s and had it on my last two BMWs, which were also on 19"s
I know that it divides opinion but I wouldn't have a BMW on large rims in this country without it
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
creepy coupe1867.00 Oceanic165.50 |
03-19-2019, 03:58 AM | #5 | |
3122
Rep 5,681
However, the fact the sports suspension set-ups from the likes of ACS and Birds are passive speaks volumes IMO; if you want to do it right you probably need to get rid of the standard BMW springs and dampers and start again.... |
03-19-2019, 04:07 AM | #6 | ||
2876
Rep 3,966
The best after market solution will always be better than OEM, I reckon, on non M cars Adaptive suspension only helps to correct the problem created by the combination of large rims, inadequate suspension components, RFTs and crap roads It shouldn't be necessary in the first place. I wasn't going to spend another £2k+ however on a brand new car so OEM adaptive was the 'in warranty' sticking plaster
03-19-2019, 05:00 AM | #7 |
483
Rep 1,189
03-19-2019, 05:27 AM | #8 | |
454
Rep 1,373
People who sell aftermarket solutions make claims which are impossible to prove as its all anecdotal. It Suffers from purchase bias and is always better than stock standard suspension. Especially if the stock suspension is worn. Lorcan couldnt explain how his fixed suspension system could beat adaptive M from BMW. I can tell you for a fact that a fixed suspension setup cannot be better than an adaptive system if you value both comfort and firmness . If you have ever had to set up a bikes suspension then you would understand that you are trying to hit a moving target depending on where you ride. It cannot be both stiff and compliant at the same time. You have to pick a compromise at the expense of one or another level of performance. Adaptive can be both compliant when needed to improve ride and firm when you want performance. Sticking a fancy set of coils painted yellow and an improved shock will never give you both of these because you are fixing the performance when you set it up and cannot change it on the fly. Adaptive can be controlled by the ECU by corner independantly if im not mistaken which gives the a level of control no fixed system can even come close to. |
03-19-2019, 06:17 AM | #9 | ||
2876
Rep 3,966
All I do know with any certainty is a) that BMWs adaptive suspension improved the ride and handling on the last three M Sport + RWD cars I've had over the stock cars I test drove before buying and b) that the best (passive) suspension set up I've experienced in recent years has been on modern Fords
03-19-2019, 06:44 AM | #10 | |
6659
Rep 15,858
What contributes to the extreme viewpoints, is often what we hone in on, or prioritize. For me, adaptive widens the working envelope, something that gives me a better working chassis. I fully understand some users want a decent passive chassis, totally predictable in all conditions, even if that means some extremes in use. The Ford Focus ST is a good example, is a very good passive setup for decent roads. Has a compliance you don't expect, combined with very good handling and predictability. Rides well, even as a passenger, front or rear. But drop the road quality and it is now outside most users 'comfort' zone. I couldn't live with it, however good it works through the twisties, (as it does up here in the Highlands). Suspension choice and the rating of what we have or like, is down to our needs and priorities. Single driver use, loaded boot, passengers, wheel choice, comfort levels, road quality, town/country/motorway use, etc., etc. BMW have to set up a compromise to suit a wide user base, be it SE, M-sport, or adaptive suspension options. None will suit everyone. The only way to really judge a suspension is to test with full instrumentation. See what the real differences are and what users rate personally, against a known baseline. I know personally I don't like a car where the natural frequency is on the higher side for human comfort. My body is very sensitive to things like head toss. |
03-19-2019, 07:10 AM | #11 |
8459
Rep 8,783
I agree, the best value and most transformative factory option available. I specced it, as did a large number of others on here. Not on the majority of fleet/lease etc. cars though.
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
03-19-2019, 07:27 AM | #12 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
Big rims + RFT tyres + "sports" suspension = poor ride. Simple.
pmgreenwood483.00 thescouselander206.00 |
03-19-2019, 07:35 AM | #13 | |
3122
Rep 5,681
As for not being able to have good handling and a decent ride with passive suspension, the two are not necessarily mutually exclusive as a drive in a Lotus would demonstrate! |
03-19-2019, 07:40 AM | #14 | ||
6659
Rep 15,858
The following is a quote from Whatcar? Now we know many on here won't be looking to Whatcar? for their preferred reviews, keep the context of advice to the wider BMW user market. Quote:
pmgreenwood483.00 |
03-19-2019, 08:03 AM | #15 |
810
Rep 1,705
I got 24% off the price of my car when I bought it new, including any options. Adaptive M-Sport suspension cost me about £400, and seems money well spent.
03-19-2019, 11:28 AM | #16 | |
454
Rep 1,373
My F33 is not light but its nicely balanced and performs well with adaptive. Sport is excellent and comform is nice when cruising. You also cannot compare to a Lotus as the weight differences and chassis is like chalk and cheese to a F31. Make no mistake its no audi magnetic ride though but then its not a 2k option either. All i know is that spending 2k on aftermarket setup might be better in some instances but wont be as flexable as adaptive. |
03-19-2019, 01:55 PM | #17 |
3122
Rep 5,681
I wasn't comparing a Lotus directly with an F31, I was merely using Lotus as an example to illustrate it's perfectly possible to have both good handling and a decent ride with passive suspension. Perhaps I misunderstood but in one of your earlier posts you seemed to imply such a combination could only be achieved with adaptive suspension?
03-19-2019, 05:09 PM | #18 | |
454
Rep 1,373
That said its all subjective anyway its probably nothing to do with the quality of the components which give you that kind of ride. Probably more to do with weight and chassis and driving position making the ride "feel" better or different I have suspension on a bike which costs more than a cars and i can tell you that its impossible to get both comfort and performance. Turn one up and the other suffers. The name of the game is to maximise grip from the tyres over different conditions. High speed and low speed compression with different rebound settings. Not to mention weight variances affect the handling. Even tyre pressure has a huge impact. Then there is sag and air or coil set ups. Even with all those settings they still come with a switch which locks out the travel to firm up the ride in 3 different settings. Adaptive M is basically a high tech version of those 3 settings on a bikes suspension. You will not get a fixed suspension set up on a road car that is both high performance and comfortable at the same time. The best we can get is a switch which allows us to select which we prefer at any given time and even that is a compromise. People often perceive good ride quality but its actually the chassis twisting or the bodying rolling or the car squating under acceleration or at worst soft tyres. All of these things are HIGHLY undesirable traits for a performance car and all of them reduce handling and traction. This is why you often see cars in the hedge as they suddenly let go. Last edited by ZeroFx; 03-19-2019 at 05:24 PM.. |
03-19-2019, 05:30 PM | #19 |
1983
Rep 3,216
I seem to recall that Top Gear tested the Golf R a few years ago, and the Stig got the fastest laps with the suspension in 'comfort' mode - mainly due to the predicatability and lack of twitchiness on the limit.
Possibly the ideal solution is to go for MSport spec, but delete MSport suspension ? |
03-19-2019, 06:36 PM | #20 | |
483
Rep 1,189
03-20-2019, 04:16 AM | #21 | |
454
Rep 1,373
Dynamic driving comes at a cost. If you ever get in to an M3/4 you will find out what harsh feels like |
03-20-2019, 04:22 AM | #22 | |
454
Rep 1,373
You are comparing dumb springs to electronically controlled independant shocks. |
