03-18-2019, 11:11 PM | #1 |
79
Rep 168
Fixing front license plate holes and transport damage
I dont need a front plate in Alberta, so I wish the previous owner of my Ontario sourced 2016 340i used the tow hook mount for the front plate...
I have bought 3 previous cars from states that had front plates and they weren't as noticeable as my new 340i. They used 4 screws. My E90 M3, Cayenne and CTS-V all only had 2 holes and the edges around the holes didnt stick out from the bumper. I simply put the 3M/Rock Guard on bumper and it didnt bother me. These holes are a little more noticeable. See pics. The transport company also damaged the right side of the bumper. I did not notice in my walk around when picking up the car as it was filthy dirty, so I am pissed at myself for that. I washed the car right away and have left Hauling co a message and before/after pics. Good thing the they forgot the credit card machine when I picked up the car and I have not paid yet. See third pic. Short of repainting the entire bumper, thoughts on how to fix this damage? |
03-18-2019, 11:17 PM | #2 |
1574
Rep 1,252
Looks like the paint is rubbed off and the black part is the bumper plastic itself, right? Unfortunately only correct fix is a respray of the bumper. Some bumper repair guys can spot touch up spray that part only, but quality can be iffy.
If I was in your shoes, I'd respray the whole bumper and get those bumper holes filled as well. |
03-19-2019, 08:23 AM | #3 |
2465
Rep 5,457
Drives: F30
The right way would be a full bumper cover respray.
I was in a similar situation and used a razor blade to carefully cut off any protruding plastic from each hole... then I filled each hole with silicone caulking... then I touched up each hole with factory touch up paint. Im fine with this set up while my bumper gets pelted with other road debris. Eventually, I will get a respray and PPF to prevent it from happening again. |
03-19-2019, 12:33 PM | #4 | |
79
Rep 168
sspade2464.50 |
03-19-2019, 01:29 PM | #5 | ||
2465
Rep 5,457
Drives: F30
Couple pics from very recently. To me its a thousand times better than a front plate... which is required by law in my state Last edited by sspade; 03-19-2019 at 08:58 PM.. |
03-19-2019, 01:56 PM | #6 | |
Guy with a car
98
Rep 224
Sounds horrible, but no one ever noticed unless I pointed it out! Happy to have a mint bumper now with no holes pre drilled
15' 435i BSM on CR // BM3 Stage 2 93 OTS // NGK Plugs Gapped 0.023" // VRSF Catless DP // CTS Turbo Intake, CP, FMIC // AWE Tuning w/ Perf. Midpipe // BC Racing BR Coilovers // Apex EC-7 // Michelin PS4S // Plus a shit load of carbon
03-20-2019, 02:23 PM | #7 |
1996
Rep 2,499
It's definitely not worth doing a full respray for just those. Any decent body shop can fill those and blend the paint to look decent enough for a couple hundred bucks. Or you can do it yourself like sspade has done. That looks good enough, IMO.
sspade2464.50 |
