Help~ car is pissing!
07-28-2008, 08:56 AM | #1 |
66
Rep 653
This is a stupid question that I should've asked when I had my very 1st car, I found out that my car would drip water from below when it's parked, ofcourse you can say it's caused by the AC... Is dripping water normal?
07-28-2008, 08:57 AM | #2 |
142
Rep 2,900
Sorry had to laugh. Yes, it's normal if you've been running the A/C. |
07-28-2008, 08:59 AM | #3 |
26
Rep 1,826
Drives: E92 335i
Yes. If you don't drip water when the AC is running it means the evaporator housing drain is plugged and your car will soon smell like mold.
That's not to say there aren't bad reasons to drip water as well, but if you're using AC I'd be way more concerned about absence of water than presence. |
07-28-2008, 09:37 AM | #6 |
66
Rep 653
ya that happened to me couple of times during spring time... I've saw a thread stating that the vent is moldy, you can fix it by cleaning it or turn on the REST or set the automatic venting time whenever its possible to get rid off the moisture.
07-28-2008, 11:01 AM | #7 |
HYEPWR
100
Rep 2,868
yeah thats your oil leaking and possibly your engine is about to go limp...oh i forgot your tranny is probably a mess too....
or its cause your AC was running
2002 330ci Titanium Silver / Gray
2005 X5 3.0i Black Sapphire Metallic / Black 2002 M3 Laguna Seca Blue / Black 2001 M5 Jet Black / Black |
07-28-2008, 11:08 AM | #8 |
Not looking 2 SPEED, just looking GOOD
45
Rep 2,516
I never noticed the water since I don't get out and but I do notice sometimes when I get back in the car, the car smells like moldy water but not all the time. Is that normal?
07-28-2008, 11:14 AM | #9 | |
26
Rep 1,826
Drives: E92 335i
It's a classic failure mode of BMW-designed ventilation systems in cars driven by Americans. It happens when the A/C has run long enough to develop condensation but not long enough to dry off. Basically when you do lots of short drives the A/C is always trying to chill hot/humid exterior air and never goes into the temperature-maintenance cycle where stuff can dry out. The official fix is to make sure there are no clogged drains, then empty a spray-can of disinfectant into the vents. |
07-28-2008, 12:31 PM | #11 |
12 yr old Juvie
1079
Rep 881
Drives: His Mom Crazy
If it's "Yellow' in color and smells funky, then I would start worrying
07-28-2008, 12:41 PM | #12 | |
15
Rep 292
This is in the manual: When the vehicle is parked Condensation forms while the automatic climate control is in operation, and then exits under the vehicle. Traces of condensed water under the vehicle are therefore normal.
2011 X3 xDrive35i F25 (CPO) Space Grey/Black Leather, Packages: Premium, Cold Weather, BMW Apps, Sirius and Technology. BMW CCA Member (WindyCity Chapter). Former cars: 06 750i E65 (CPO) 07 E90 335i (bought used but had problematic iDrive so sold it to get 7-series)
