03-18-2019, 12:51 PM | #1 |
Rep 20
The Sound Never stops! backup cam with sideplate
As i live in VA and front plates are required, I opted to not drill holes in the front bumper and went with a side-plate (spare me your cynicism about a side plate being ugly or whatever).
A huge problem though is dealing with the intermittent beeping on my backup cam. The plate confuses the front censors and leaves a perpetual "beeep" as I back up. Any solutions? Is there any possible beemercode coding to remove one front sensor "cell?" I lowered the PDC sound as much as possible but it still makes my ears bleed. |
03-18-2019, 01:03 PM | #2 | |
731
Rep 1,045
03-18-2019, 01:41 PM | #3 | |
275
Rep 799
https://bigmikesperformanceparts.com/
mlev370.00 |
03-18-2019, 01:49 PM | #4 |
80
Rep 53
Drives: Too Fast!
That must suck, the PDC can be so annoying at times. I think that there’s a way to code them out via Bimmercode expert mode, but you might also consider just unplugging the sensors and coding out any error messages.
03-18-2019, 02:13 PM | #5 |
370
Rep 552
Did you buy the front plate bracket designed for cars with PDC?
They incorporate different holes and a different design. These are made specifically for the F30. If you didn't buy the PDC specific front plate bracket, you bought the wrong kind |
03-18-2019, 02:27 PM | #7 | |
370
Rep 552
http://www.usmillworks.com/bmw_front..._tow_hook.html https://www.cravenspeed.com/the-plat...mount-for-bmw/ Visually my favorite is the STO N SHO, which I bought but never installed: https://bigmikesperformanceparts.com...-plate-bracket |
03-18-2019, 02:32 PM | #8 |
9
Rep 48
Kies Motorsports posted a youtube video reviewing a tow hook plate holder specifically designed to not interfere with PDC. You might want to check it out:
03-18-2019, 03:32 PM | #9 |
238
Rep 878
How does that side mounted plate look better, looks like a pimple on the car and would much rather have a centrally mounted plate.
03-18-2019, 04:35 PM | #10 |
1599
Rep 3,748
This is the to that other thread about tow hook plate holder.... it won't clear the PDC on my 428i gc. I got a central plate mount
I use this drilled on the underside of the bumper: https://goo.gl/images/6quGjn |
03-18-2019, 07:56 PM | #11 |
1039
Rep 1,509
I epoxied three heavy neodymium magnets inside the front bumper shell. On the back of my plate, I bolted on one of those rubberized magnetic strips that they sell to car dealers.
To remove the plate, I just grab and pull. To put it back on, I just hold it to the bumper and the magnets snap it in place. I've driven several thousand freeway miles with it in place and it hasn't fallen off yet. |
03-19-2019, 07:26 AM | #13 |
280
Rep 391
Drives: F87 M2C
I got a US Mill Works one and they said it only works one way with a certain version they sell. I wanted to move it a little without triggering the sensor. I glued pieces of felt to the areas triggering the sensors and it works 95% of the time. And when it rains it gets wet it stops working as well.
