03-17-2019, 05:41 PM | #1 |
135
Rep 234
Super small oil leak, can anyone tell me what this part is?
I purchased my 340ix CPO about a month ago and I started noticing a bit of oil (maybe a dime worth) on my floor of my garage the last two nights. Got under the car today and noticed the following.
Can anyone tell me what part this appears to be? Just want to have a clue before I talk to a service advisor tomorrow. Last edited by Ahanix; 03-17-2019 at 05:47 PM.. |
03-17-2019, 06:00 PM | #2 |
2466
Rep 5,457
Drives: F30
Looks like the transfer case to me...
03-17-2019, 06:01 PM | #3 |
2466
Rep 5,457
Drives: F30
^ there is a drain plug visible and an axle sticking out of it...
You are also xDrive. Its definitely your transfer case leaking. |
03-17-2019, 10:02 PM | #4 |
135
Rep 234
03-18-2019, 10:20 AM | #7 |
135
Rep 234
No other leaking present, if you look at the bolt from those angles you can see it appears to be leaking out of that lower area, almost like the bolt isn't tight enough. I'll be taking it in tomorrow and will keep you posted.
03-18-2019, 10:29 AM | #8 | |
1781
Rep 4,456
Just had a oil leak fixed under CPO. |
03-18-2019, 10:42 AM | #9 |
2466
Rep 5,457
Drives: F30
I do agree, looks a bit dark for gear oil but it does appear to be coming directly out of the transfer case (third pic).
Then again, when I replaced the gear oil in my rear differential last month - it was BLACK... not clear like when it goes in fresh. Interested to hear what the dealer tells OP. |
03-18-2019, 12:42 PM | #10 | |
135
Rep 234
Thanks for the info, this has been really helpful! Trying to get all of this squared away before Bootmod3 for B58 is released. |
sspade2466.00 |
03-19-2019, 11:26 AM | #11 |
135
Rep 234
Figured I would update this thread. Service found a leak on the turbo oil return line and are ordering it in and fixing it tomorrow. Was just a coincidence that it was dripping down on the transfer case.
obert1781.00 |
03-19-2019, 02:02 PM | #12 |
121
Rep 470
Are they replacing the turbo as well? A leaking return line points to issues with the turbo and getting old oil out/new oil in. I'd be a pest about it and make sure the return line was physically broken and not leaking from where it connects to the turbo.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
03-19-2019, 02:16 PM | #13 | |
135
Rep 234
They were just going to replace the o-rings, but the technician came back and said the line should be replaced as a precaution (I am assuming based on this comment that it is broken) Thanks for the heads up, I am going to push on them about the Turbo. I don't really need a failed turbo / reason to get a Pure Turbo any time soon, especially when I'm still under warranty. |
02-08-2023, 07:43 AM | #14 |
Rep 1
OP I know it’s been a while but any update on the repair? How’s it holding up? Recently had an oil leak as well and your post was identical to the leak I have. Going into service today
04-10-2023, 05:28 AM | #15 |
Rep 2
Have almost the exact same leaking. Oil adds up under the front diff after a coupel of days.
2019 340i with only 30000 miles. Taking it to service tomorrow. Last edited by danneha; 04-10-2023 at 05:52 AM.. |
04-10-2023, 05:29 AM | #16 |
Rep 2
