03-13-2019, 10:29 PM | #1 |
Rep 3
Drives: 2015 F30 335xi
First, I'm in a 2015 335i with a VRSF catless downpipe, I already tried the VRSF downpipe fix, wired everything correctly and it didn't work, heard it only works on PWG cars and mine is EWG, not my question though and not looking to try another "fix".
Second, I am running MHD Stage 2+ and don't know if that will mess with my readiness, Do I need to flash back to the stock map? and Third, I've come to the conclusion that i'm just going to replace my catless downpipe with my old OEM catted downpipe. So my main question is, if I switch to the stock map on MHD, and re-install my OEM catted downpipe, will I pass emissions? and if not what do I need to do? |
03-14-2019, 04:59 AM | #2 |
Uhh... Khakis?
54
Rep 155
You’re right, the catsim will only work on PWG. Put the stock DP on and upload the stock tune then buy a $15 OBDII reader to confirm readiness. You will need to complete a drive cycle to achieve readiness, see below:
https://www.instructables.com/id/How...or-Smog-Check/ |
filthy_F300.00 |
03-14-2019, 03:31 PM | #3 | |
2413
Rep 4,451
Drives: '23 X1 28i xDrive
#GIGO Good luck. |
03-14-2019, 06:18 PM | #4 | |
4488
Rep 10,473
Maybe. GL |
03-16-2019, 11:59 AM | #5 |
521
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
you have mhd...flash what ever tune and just drive the 50+miles within 3 cold/hot cycles at 40-60mph to get you to ready state... should be all good.. .
filthy_F300.00 |
