BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    M5C sport exhaust valves close all the time?
      03-10-2019, 04:54 AM   #1
onlyoujames
onlyoujames's Avatar
Australia
9
Drives: BMW F90 M5
M5 competition sport exhaust valves supposed to be closed even when you change to Sport and Sport Plus Modes?
      03-10-2019, 05:48 AM   #2
M135iXdriver
M135iXdriver's Avatar
Switzerland
200
Drives: BMW M5 Competiton
Location: Northwestern Switzerland veeeeery close to the German Autobahn
The valves should be open at default when the engine starts, you can push the button to close the valves. When changing to sport or sport+ the valves should open again if closed or remain open if they already were.
2019 - BMW M5C MY2019 (Individual Urban Green)
2016 - VW Passat B8 2.0 TSI (276 bhp) R-Line (sold)
2013 - BMW M135i xDrive 3.0 (316 bhp) (sold)
2010 - Mazda 3 MPS BL 2.3 (256 bhp) (sold)
      03-10-2019, 06:23 AM   #3
onlyoujames
Australia
9
Drives: BMW F90 M5
I was wonder why my M5C sounds very muffled! Will send it to my dealer and have them checked.
      03-10-2019, 12:08 PM   #4
AgentMax
AgentMax's Avatar
Germany
24
Drives: F90 M5 Competition
Maybe because it isn't very loud at all with stock exhaust.
Just do some revs and turn on/off the valve button. If you hear a difference its working fine.
      03-10-2019, 03:43 PM   #5
marcvtec
407
Drives: M5
The only time it would be closed in that scenario is if you have the muffler button in the off position, that is the 5th button down the side of the gear selector. want noise (there should be a green light on)
      03-10-2019, 08:33 PM   #6
M4LAKA
114
Drives: 2022 M5 Comp
I still think it only opens valves in higher rpm. I don't think it opens it in idle or in low rpms
Currently:
2022 M4 Comp xDrive
2022 M5 Comp
Past:
2019 M5 Comp
2015 M4
      03-11-2019, 03:18 AM   #7
Miller uk
Drives: 2018 M5 Comp
The way I understand it is in "efficient" valves closed regardless of button on centre console. Sports / Sports plus valves open (green light on ) but you can close them by pushing the button (green light off). If you want to test, before starting car, put it in sports plus and then start up you should notice a louder start than when starting in efficient mode
      03-11-2019, 09:23 AM   #8
M135iXdriver
Switzerland
200
As far as I know this should not be the case. It's an unique feature that when you start the car the valves are always open (green light on) and stay open until you push the button. That's how I was told by a BMW Genious.
If someone could test it, my guess is there should even be a difference in economy mode.
      03-11-2019, 05:21 PM   #9
Drm5
Puerto Rico
30
Drives: F10 M5 sakhir orange
man you will feeeeeeel de diff. in sport plus since the vibration from the gear change are wild ..!!!
Appreciate 2
      03-11-2019, 10:06 PM   #10
onlyoujames
Australia
9
Drives: BMW F90 M5
Sent my M5c to dealer again yesterday! Not just checking the exhaust valves but also checking the exhaust rattling noise which started last Thursday and getting louder and louder since then. It sounds like some part of the exhaust pipe vibrates against something and happens during the start up and when engine at low rev.
I am not sure if the flap valves and noise are related but will wait for my dealer to come back to me.
      03-12-2019, 02:20 PM   #11
turbomcgee
75
Drives: 2018 M5
In sport plus the valves open and close based on a number of things..load, throttle, RPM. - and even when first starting the valves do not always open.
I have my valves permanently open, by unplugging the harness to the actuator when the valves were open. There is a big difference under part throttle and cruise with them open full-time. - my dealer even gave me dummy plugs for the OEM harness.
      03-12-2019, 06:08 PM   #12
marcvtec
407
Drives: M5
Bingo - when start up complete valves are open,
Having said that, even during the (green light valve on).
Eco mode less sound, sport a bit more, and sport + lots of sound.
So two things probably happen, the valve to the secondary pipes open, lets say 20%, 50% - sport, 100% sport plus.
As well as the dumb asd inside noise changes, in the same regard.
Simple huh. .
By the way I also have the sport Exhaust.
Appreciate 2
      06-05-2019, 11:16 AM   #13
dappercivility
dappercivility's Avatar
204
My F90 M5C with the M Sports Exhuast has the exhuast button on during startup in default. I tried to switch it off by pressing the exhuast button till the green light is off but the exhuast is still ridiculously loud during start up. It seems the exhuast valve remains open despite the green light on the exhuast button is off?
Born in M Town
      06-05-2019, 10:40 PM   #14
onlyoujames
Australia
9
Drives: BMW F90 M5
Yeah, it's loud during startup. I kind of like it and hate it depends locations! However, I found the valves will close after startup and open again when the car warm up if the green light is on. The valves will open permanently in sport + mode.
      06-09-2019, 06:05 PM   #15
av.7447
180
Drives: E39, E60 M5, F06 M6, F15, F90
I have a Canadian non-comp 2019 M5 with a sport exhaust option. What I observed is that valves remain closed during the startup even though exhaust light is on. Also it remains closed throughout all the mods while idling. If I put it in sport plus and rev it up a few times, the exhaust valves open and stay open after that... I am thinking maybe different countries have it programmed differently based on the local noise restrictions??? Also backfire crackles work only in Sport Plus setting. Go figure....
      06-18-2019, 11:50 AM   #16
gtenedio
Drives: '%E2%80%9909 e92 m3, '19 X3, %
the exhaust button should be more referred to as the "burble button" as it just intensifies such. the note is minimal difference on the base models. more so on comps.
for those running at minimum secondary downpipes- will hear the difference slightly more as well
      06-18-2019, 11:56 AM   #17
gtenedio
indeed- sport plus is not as black and white as previous platforms, the baffles open when the car senses some speed ( this is more similar to non m's such as the m40 models IMO.)
whereas the f80 would switch on immediately upon selecting sport or sport+
surprised there isn't an exhaust flap override yet with the JB4. this was clutch on my f80, where I programmed it to stay on 100% of the time.
maybe we can get this if someone can tag a BMS rep here
