03-09-2019, 05:36 AM | #1 |
313
Rep 570
For those who use Millers Eco Max
Especially those who use it by the 5L can, i discovered the 500ml dispenser is not refillable and any other attempt I made to put it in a container, went a little awry.
A quick google and this turned up - https://www.ebay.co.uk/itm/1L-Natura...72.m2749.l2649 Arrived today and works spot on, A longer spout would be helpful, (fnar missus) but I thought I would share. I called Millers and confirmed that it needs to be HDPE which this is so it shouldn't dissolve the container in the boot, its slightly over doses but not enough that it will make any particular odds. Hope this helps someone else. Ps. Im not opening the debate about Millers or not, my experience is it is worth it. Cheers Alex
335d XD Shadow Edition - Mission intergalactic mileage underway
03-09-2019, 07:18 AM | #2 |
391
Rep 811
Some more advice from me...
The raw ingredient in Millers that improves Cetane is the chemical 2-EHN - you can see this is mixed with 'filler' in Millers on the technical datasheet. You can buy the pure stuff off Ebay. Buying in bulk and accounting for the purity, it works out at about 1/6 the price of Millers! I just mix a dose with diesel or whatever before dropping it in the tank. Just grab a few 100ml safety bottles and keep them in the boot bin. Edit: make sure you use nitrile gloves when handling. Its very hard to wash off your hands. This is what i get: https://www.ebay.co.uk/itm/Hydra-Fue...EAAOSwqu1avw~L Last edited by Eddamoo; 03-09-2019 at 07:23 AM.. |
TiredGeek360.50 |
03-09-2019, 07:54 AM | #3 |
2472
Rep 4,653
@Eddamoo what's the petrol version of this?
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
03-09-2019, 10:03 AM | #4 | |
169
Rep 271
thanks
Ex S3 & GLA45 AMG ... now 435d F32 coupe
03-09-2019, 11:35 AM | #6 |
391
Rep 811
Nothing from what I remember. I'm pretty certain the data sheet only mentions paraffin. That is a little less viscous than diesel so may help cleaning, but in the tiny amounts of Miller's, not a chance!
03-09-2019, 11:39 AM | #7 | |
391
Rep 811
It certainly reduced diesel clatter and soot on all my diesel cars since 2005 |
03-09-2019, 02:49 PM | #8 | |
313
Rep 570
Interesting to know the main ingredient can be purchased separately - Do you reckon any of the other ingredients help suspend the mix in the diesel?
03-09-2019, 06:02 PM | #9 | |
391
Rep 811
Here's the Wynn's equivalent MSDS. As you can see, a little 2EHN, loads of Kerosene and a few solvents. http://www.wynnoil.co.uk/wp-content/...-3_EN_MSDS.pdf Last edited by Eddamoo; 03-09-2019 at 06:20 PM.. |
03-10-2019, 03:21 AM | #10 |
Old Fart
361
Rep 694
Thanks for that, I always wondered if the Millers was basically just one active ingredient with a carrier oil.
I think "Millers" is worth adding, in my previous car (Volvo D5) I didn't start using it until around 70k miles but after 10k or so I noticed that I was getting better mpg than previously, and that the DPF was asking for fewer regens. When I sold it at 125k it was doing around 6mpg better and the intake manifold was far less sooty than other cars of the same age and mileage. Now I know it's just due to better combustion leading to lower soot levels I'm switching when my Millers supply is gone OK, plastic or metal bottles? https://www.ebay.co.uk/itm/PLASTIC-S...53.m1438.l2649 https://www.ebay.co.uk/itm/2Pcs-Safe...53.m1438.l2649
The doctors said it's OK to listen to the voices..... just don't do what they tell me
03-10-2019, 03:27 PM | #11 | |
391
Rep 811
They should fit a nice 1:1 or 2:1 mix of 2EHNiesel. I live near a filling station so dump in a plastic bottle full before leaving home. |
03-13-2019, 04:39 AM | #12 | |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
03-15-2019, 05:29 PM | #13 | |
171
Rep 468
Millers eco max is just that, 2 EHN but double the price. 2-ethylhexyl nitrate (2-EHN) is now the main ingredient in todays diesel fuels for cetane increment since the removal of sulfur, which used to be the cetane booster back in the day. My friend actually works in the refinery and he told me that they use 2EHN as boosting agent to bring the cetane numbers up, and for example when you buy BP Ultimate or Shell V-Power, basically you're buying the same fuel but with a higher does of 2-EHN to bump up the cetane numbers.. |
03-16-2019, 06:03 AM | #14 | |
391
Rep 811
Tuning for power is different to modifying a static tune. If you perform a tune for more power, you're adding more fuel and therefore needing more time to burn it. That's the only reason why you'd advance the ignition. We're not talking about that in this thread however. |
