BMW X5
      03-08-2019, 10:22 PM   #1
ScotsWhaHaeWi
Drives: 2019 X5 40i
Tire Pressure with replacements
I got my 40i with 20" RF and the spare tire option with the plan to change to NRF soon. The door plate tire pressures for the supplied Bridgestone Alenza RF are quite a bit higher than I'm used to seeing.
I'm wondering if the pressure recommendation will stay the same if I put, say, Michelin Sport non RF on? Anyone have insight?
      03-08-2019, 10:32 PM   #2
AndroidRobot
AndroidRobot's Avatar
Drives: 2022 Porsche Boxster GTS
  [0.00]
2022 Porsche Boxste ...  [0.00]
I go off iDrive usually. The door plate isn't wrong, you should run those pressures at a minimum unless otherwise noted. Best way to confirm is to have someone with 20" Non-RFTs post their door tag
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order)
2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD)
2018 BMW M2 Mineral Grey(SOLD)
2019 BMW X5 50i Carbon Black/Tartufo (SOLD)
      03-09-2019, 04:47 AM   #3
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Drives: What he wants to
That's funny, I've also got 20" with Bridgestones and I thought the recommended pressure was much lower than I'd expect for a large tire on a heavy vehicle.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch
      03-09-2019, 07:06 AM   #4
mattsrs
615
Drives: X7
Can you exchange the RFs with NRF? I want to do that but don't want to spend one whole new set of tires when RFs are new. Is it common for tire shops to do exchange?
      03-10-2019, 03:44 AM   #5
sygazelle
11341
Drives: 2014 328i M-Sport, 2019 X5 40i
I thought I would be getting rid of run craps as soon as possible too but I can't believe I'm saying this...the Bridgestone 20"s are not horrible. Yes, I will want go flats when its time to change, but I'm happy to wait until the OEM tires wear out first.
      03-10-2019, 07:22 AM   #6
Mark609
Drives: 2019 G05 Xline
My 19" are comfortable and handle really well. I'll probably switch to regular tires as soon as these wear out and if I have a flat will call roadside assistance.
Regarding PSI - No matter the tire or vehicle I've always used the Max. pressure rating as stated on the sidewall as a guide and pressurized them at or just below Max. Wear has been great. I recently changed from 44 PSI front/back based on the door sticker to 33 fronts, 44 rears.
Can't tell much difference.
Here's the kicker....with the weight of the engine being borne by the front tires, why would the factory recommend they be less than the rears?
      03-10-2019, 07:44 AM   #7
rmorin1249
rmorin1249's Avatar
817
Drives: 2019 X5 MSport 40i
I have the 20" Pirellis and I believe the door plate says to run 36 Front and 41 Rear. This is higher than I am used to but this is the first BMW SAV I have owned.
COL(Ret), US Army Hagerstown MD
2019 X5 40i MSport Alpine White/Coffee (my 13th BMW)
2015 Mercedes SL400; 2009 Lexus RX350
      03-10-2019, 07:48 AM   #8
mattsrs
615
Drives: X7
Do you have spare tire package? I'm thinking about replacing RFs with regular as well but like to have spare in that case. I didn't order the spare package and my CA says I cannot fit spare in trunk as the molding of compartment under trunk cover is different (than with spare package) so it won't fit
      03-10-2019, 08:25 AM   #9
Mark609
No. I tried to add it before production but the VIN had been assigned. Now if I want it I have to pay like $500 is a rip. I've come to the conclusion that since we have roadside assistance it's a big waste of money and space. There's a lot of useful storage space in that area.
I believe your CA is right as mine advised me that on some BMW's the spare will raise the deck it's under.
Just get your regular tires come time and a can or two of a tire sealant for emergencies or enroll in AAA roadside assistance after the 4 yr. BMW term.
mattsrs615.00
      03-10-2019, 09:09 AM   #10
rmorin1249
rmorin1249's Avatar
817
Pretty sure the higher recommended PSI in the rear is to account for max luggage weight. Also running lower PSI in the front encourages understeer to avoid the rear end kicking out but this is rare with all the nannies turned on.
Mark609166.50
      03-10-2019, 10:46 AM   #11
ted99
Drives: former i3>330e, 528i>X5>530e
After changing out my RF's on a 2015 528i after a 1000 miles to non RF's because of their non-compliant ride, I also was pleasantly surprised by the RF's on my 2018 X5 40e with 19" tires. I decided to keep them. However, I'm accustomed to getting at least 40,000 miles from non-RF tires on past autos and I am not impressed by the wear on these RF's. It looks like I'll struggle to get 30,000 miles. At 10,000 miles, I had 2 mm more wear on the rears, than fronts; so I rotated the tires. Door plate pressures maintained at all times.
      03-10-2019, 03:43 PM   #12
Mark609
Yeah, I usually get 60K miles on go flats.
xbimmers
