BMW M5 F90 (2018+) General Forums Cosmetic Modifications    Pro Spoiler Install Issue?
      03-06-2019, 10:37 AM   #1
KDDeutschland
KDDeutschland's Avatar
Drives: 2018 M550i
So Im having a M performance pro spoiler attached and the dealership calls me and says there is a problem. The new spoiler doesn't cover the same area as the factory spoiler and they cant match the paint because of the frozen color. Has anyone else had this ridiculous issue before? If so how much of the area from the factory spoiler was covered by the M performance spoiler. Im worried that i will have an inch or so of mismatch paint on my trunk.[IMG][/IMG]
The Bishop Has Blessed You?
      03-06-2019, 10:48 AM   #2
trev230
trev230's Avatar
351
Drives: 2022 M5C
I installed mine but I have regular Alpine White paint. It definitely does not go in the same spot and I had to clean up the area and polish it a little. Not sure how to handle that with a frozen color. The factory betalink glue is a pain in the butt to remove. I used high quality 3m trim tape and cut the pieces to fit the underside of the M Pro spoiler and it fit really well. Didn't want to deal with the glue again if I decided to put the factory spoiler back on.
Gmacf87173.00
      03-06-2019, 10:51 AM   #3
KDDeutschland
Drives: 2018 M550i
Crap, that sucks. Quick question though. How much if the old area dis the new spoiler cover? Was it a noticeable difference? I cant buff out the color differences. Frozen paint cant take it.
      03-06-2019, 11:02 AM   #4
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
I think it mounts about an inch back from the stock one if I can remember right. It definitely doesn't cover the same area
      03-06-2019, 11:04 AM   #5
KDDeutschland
Drives: 2018 M550i
Shit...😩
      03-06-2019, 11:06 AM   #6
KDDeutschland
Drives: 2018 M550i
Shit...😩
Im hoping an inch wont be too noticeable. BMW really pisses me off with this kind of nonsense. If you are going to sell a Frozen paint option then properly train your techs in how to deal with it!!🤬
      03-06-2019, 11:12 AM   #7
Ever34
325
Drives: F90 M5
There's going to be quite a bit showing.
      03-06-2019, 11:36 AM   #8
KDDeutschland
Drives: 2018 M550i
Yeah thats what I thought...
      03-06-2019, 12:29 PM   #9
Simon H
Simon H's Avatar
876
Drives: M5 Competition
Trev,
Does the spoiler feel rock solid with just the 3m tape ?, im about to fit one to my car, and im unsure whether to use 3m tape or betalink ?. Ive fitted 2 M4 rear spoilers before with 3m tape, and they were both rock solid, and were not coming off, unless i was taking them off. Thanks for your advice ?.
      03-06-2019, 01:16 PM   #10
trev230
trev230's Avatar
351
Drives: 2022 M5C
Originally Posted by Simon H View Post
Trev,
I can grab mine and try to pull it off and it won't pull away. Now if I went and rocked it back and forth with excessive force then yes I could probably wiggle it loose in some places. I would really have to press and pull on it hard though. It's on the trunk really good. I did take a lot of time to cut the tape in certain areas to shape it the same as the spoiler, also doubled it up in some areas especially near the corners. Also, prepped the areas with alcohol, etc.. I taped it down overnight as well with blue paint tape.
Simon H876.00
      03-06-2019, 04:53 PM   #11
boredM
124
Drives: Ford F-350 & Nardo F90
before you get too far show the pics to a high end detailer in your area and see if he can do anything with it.
Id be willing to bet he can fix the shade difference.
      03-06-2019, 05:21 PM   #12
Aronis
Aronis's Avatar
2272
Drives: 2018 M5
Was the Frozen Paint job done with the spoiler in place? I thought the car was painted first and then the spoiler was added? What paint is under it? Just primer??
What happens if you have an accident? Do they ship the car back to Germany for a paint job??
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      03-06-2019, 07:52 PM   #13
Pimpsy
420
Drives: 2019 M5C
Mike
The problem is that the adhesive leaves the paint blemished and it's very difficult to restore the original look.
If you can't get it right, just put the original spoiler back on.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
      03-06-2019, 07:59 PM   #14
Ever34
325
Drives: F90 M5
Wonder if you could just get xpel stealth on the trunk after spoiler install. Just throwing it out there not sure if you would then see a difference with the rest
MCOMP199.00
      03-21-2019, 08:24 PM   #15
MCOMP
MCOMP's Avatar
199
Drives: 19' M5 Comp.
I'm in the same boat, I like your Xpel idea.
2019 MBB/Aragon M5C
M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp
      03-21-2019, 08:25 PM   #16
Spoolin Montego
Spoolin Montego's Avatar
602
Drives: 16 m3/20 x5m/23 m3
IMO dont mount the spoiler, its gonna bug you. If it was my car I would sell the spoiler and get one that sits on top and completely covers the area
      03-22-2019, 07:00 AM   #17
MCOMP
MCOMP's Avatar
199
Its a tradeoff, Orig. spoiler will cover area but falls short of an M spoiler whereas the Pro looks great but will leave the blemished area exposed visible up close only, 3rd option is the $1295 high kick spoiler which is twice the price and doesn't look as good as pro but will cover blemished area.
2019 MBB/Aragon M5C
      03-26-2019, 12:42 PM   #18
jalkster
220
Drives: X3MC
Did you end up doing anything?
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T
