03-05-2019, 05:38 PM | #1 |
40
Rep 134
UK 340i 16 Plate Private Reg Plate Query
Hi, as title says above, I have a query.
Im looking at buying a private reg plate. But my issue is with the physical plate, front and rear. How dod I get the best mount. I'm not sure if it has a mount behind the current plate on front or back currently. I don't want to use sticky adhesive. I'd rather have it screwed on. Any ideas, any companies, anybody with experience and how? |
03-05-2019, 06:07 PM | #2 |
240
Rep 1,756
I assume the plates you have now are screwed on? The rear plate screws direct to the boot, the front normally has a mount screwed to the front bumper, my plates have always been screwed on
03-05-2019, 06:35 PM | #5 |
459
Rep 1,412
Buy the plates and drill some holes in them....??
Steven1077240.00 Pequin230.00 |
03-06-2019, 03:23 AM | #7 |
73
Rep 187
Drives: 330d f31 msport
As above but ,
Drill slowly with no pressure , use a sharp drill bit and drill thru plastic plate into a price of wood , to avoid splitting new plates . !! |
Pequin230.00 |
03-06-2019, 06:23 AM | #9 |
463
Rep 1,049
Drives: F31 320D Xdrive Msport+
Or you could get some plate surrounds I had these genuine German dealer ones (the Munich dealer closest to the welt) with pressed metal plates on my E91 didn't go this route on my F31 but it's a solution for non drilled plates.
[url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Click here for the Bimmerpost UK Refugees - Censorship Sucks![/url]
03-06-2019, 06:41 AM | #10 |
110
Rep 92
03-06-2019, 03:49 PM | #11 | |
343
Rep 635
Drives: 911 Turbo S, X5 40i, XC90 T5
Always use a smaller drill bit to make the initial hole and then move up to the larger drill bit. Personally, I prefer the cleaner look of having the rear plate stuck on and then I drill the front plate. |
ShavingChimps109.50 |
03-07-2019, 12:24 AM | #12 |
81
Rep 159
After drilling plate apply a couple of coats of the Mrs' clear nail varnish, around the inside of each hole, to stop water ingress. Stops that horrible stained effect when the layers separate.
_________________________________________
M135i F40 2020 - Misano Blue l Tech Pack 1&2 l Comfort Pack 1&2 l Adaptive Suspension Previous: 335d F31 MSport 2017 - Sapphire Black |
03-08-2019, 04:15 PM | #14 |
343
Rep 635
Yes you do. Also if you have your vehicle is leased or financed under a PCP they also need to be informed (if it's funded with an unsecured loan it's not an issue).
03-08-2019, 04:45 PM | #15 | |
157
Rep 429
Also drilling a pilot hole can cause cracking so just use a sharp drill at moderate speed and low pressure. |
C320342.50 |
