03-04-2019, 11:30 AM | #1 |
Rep 7
Broken dme help
Okay so I'm running a bootmod3 stage 2 tune and i was getting some misfires, so I ordered ignition kid from fcp euro to replace plugs and coils as that would be the first idea to fix. Ran car before working on it , no codes or atleast significant ones. After working on it and finishing up i went to start it up and nothing, it just cranked but never kicked over and started. Ran codes and i got a multitude of short circuit codes. Only thing that i can even think of is when i was working on it my ratchet touched a metal piece it couldve been a terminal im not sure tbh but it sparked up for a second. Really hope i didnt fry my car/dme and i just didnt install the plugs correctly or something. Im clueless
113027 relay ignition injector, supply voltage injection line break 1f0515 valvetronic supply voltage cable disruption 1f4a02relay ignition/injector control short circuit to ground 133102 valvetronic relay control short circuit to ground cd9010 1b5202 terminal 15n_1 care provided by cas electrical short circuit to ground 1b5402 terminal 15n_3 1b5302 15n_ 2 130002 /130202 vanos solenoid valve inlet outlet short circuit to ground 122002 diverter valve control shortcircuit to ground 12b102 lambda probe heating before cat control short circuit to ground 123002 wastegate ansteurung kurzschluss nach masse 102a01 air mass meter signal electrical fault 164020 inlet camshaft sensor electric short circuit to positive 164030 exhuast camshaft electric short circuit to positive 1C0202 Engine oil pressure control valve , control short circuit to ground my shop says i fried my dme what do you guys think ? |
03-05-2019, 06:00 PM | #2 |
296
Rep 2,015
Take it to dealer, here is why.
They have a Tool that they Plug in between DME and your Car and can Diagnose what exactly is wrong with it. I had a resister fried on my DME on my e90 and the dealer was the only one that could help me with it, by telling me that it was the DME, cause I was chasing an O2 code for 2.5 months. and if it is the DMW, then watch this video and call him. Best Recommendation I can give. Custom DME programing available. Contact: +1.985.492.0666 call/text or email GcodingBMW AT Gmail.COM Facebook: www.facebook.com/GcodingBMW |
