03-04-2019, 10:47 AM | #1 |
26
Rep 72
Where are the F30 (N55) engine ground points
Hey ppl
My f30 335i (N55) is experiencing an issue with a fairly new battery where the battery seems to not be charging properly so the voltage remains pretty low (11.5V). Every now and then the start stop will deactivate as a result, and also once in a while I'm getting a long crank followed by a low battery error. The battery is still fairly new so I suspect it's something else. The voltage with the car switched on is around 14.8V so that seems to be fine, so I'm wondering if my engine ground is possibly corroded so presenting a high impedance. Can someone point me to exactly where the engine ground strap is located, with pics if possible? Also, is it possible to see it from the engine bay without getting under it? |
03-04-2019, 03:25 PM | #4 |
8245
Rep 16,089
I don't think the engine ground strap would cause the battery to not take a charge. You can read the alternator output and the battery charge at the charging posts under the hood. If it reads 14.8v there when the engine is running and only 11.5v when it's not that indicates either a bad battery or a bad voltage regulation circuit that's preventing the battery from fully charging.
03-06-2019, 11:53 AM | #7 | |
153
Rep 258
