03-03-2019, 03:48 PM | #1 |
58
Rep 197
Trunk opening randomly
This has been happening for about a year now off and on, but I noticed mostly the day of/after I get my car washed. The trunk will pop open (no flashing lights to indicate comfort access kick feature) and the latch will continue to click as if you're trying to open the trunk again and again and again while it is already open.
The first few times this happened, I did some research and decided to see if it was the key fob. I can confirm it is not the key fob button sensitivity because I can literally put the key on the floor and close the trunk and within 3-4 seconds it'll pop back open and continue to 'unlatch' the already open trunk. If the car is locked, it will unlock the car. Has not happened yet while the car is on, and only ever while parked and off. I've concluded that this has something to do with moisture somewhere as again it really only happens very soon after a car wash. I'm going to take the car into the dealer as warranty is about to expire, what sensors/etc. should I tell them to look at to make sure they don't just try to reprogram my key fob and blame user error? |
03-03-2019, 04:11 PM | #3 |
58
Rep 197
03-03-2019, 04:18 PM | #4 |
1646
Rep 4,877
I believe the car pops the trunk if it thinks you closed it with a fob inside (just like the doors refuse to lock when the fob is in the cabin).
03-03-2019, 04:19 PM | #5 |
58
Rep 197
03-03-2019, 04:44 PM | #7 |
2413
Rep 4,451
Drives: '23 X1 28i xDrive
03-03-2019, 04:49 PM | #8 | |
2413
Rep 4,451
-You have the key fob next to the trunk and you grip the trunk handle. -You have the key fob next to the trunk and you kick swipe under the bumper. -You close the fob in the trunk -You press and hold the trunk button on the fob -You press the trunk button inside the car. You tell the service advisor that you have done none of these things, and yet the trunk still keeps opening. The problem you are going to face is if they can't replicate the issue. If you can wash the car between now and your appointment, try and get a video of the trunk doing this mysterious opening. That should substitute for the dealer replicating the issue, or maybe preserve your warranty claim after the warranty expires if they can't replicate it, since you can show it happened before expiration. Good luck. |
03-03-2019, 04:53 PM | #9 | ||
58
Rep 197
That leaves the fob being nearby and opening the trunk when the handle is gripped. I see this as likely and could see it correlating with car washes. Maybe moisture is triggering something under there? Concerning nonetheless. My appointment is tomorrow along with a plethora of other things I want to get done before warranty is up. |
03-04-2019, 11:38 AM | #11 |
Just Copacetic!
177
Rep 616
When I'm washing my F22 which has comfort access, the door locks will lock and unlock as water is flowing over the handles (key is in my pocket) as I'm rinsing off the soap. Sounds like your issue is water acting as a conductor.
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite |
03-04-2019, 04:40 PM | #12 | |
58
Rep 197
Sub zero wind chills here in Chicago so we couldn't wash it there to see if it happens. A short would store a code, correct? |
03-04-2019, 05:10 PM | #13 |
38
Rep 172
I had this happen a couple times before, when I walked by the trunk with the fob in my pocket, the trunk would pop. I think it had to do with the "foot" sensor under the rear bumper, I thought maybe it was really dirty and was detecting something there.. It went away after cleaning the car..
Wagner Competition Intercooler, ER Chargepipe, Fabspeed Catted Downpipe, Bootmod3 OTS Stage 2 93 oct
03-04-2019, 05:15 PM | #14 |
Rep 2
Drives: 2014 328i bmw
Trunk opening
Not sure either I have also had that happen to me I just thought I hit the trunk release button on the fob.
03-04-2019, 05:40 PM | #15 |
2000
Rep 3,680
Might be worth looking at the kick sensor under the rear bumper? Just a thought, probably not it but figured I'd through it out there. Maybe take a look under there to see if there's any obvious problems.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
03-04-2019, 11:06 PM | #16 |
1039
Rep 1,509
There's a TSB out there someplace that involves coding the trunk lid to require you to press the door unlock button first. Should be a warranty service.
03-04-2019, 11:28 PM | #17 |
477
Rep 797
I've came down to the garage to leave for work and found my trunk hanging open a number of times. It happened last Thursday and again this morning. The light is on so I don't think it's open all night.
What I think it is is accidental pressing of the button, caused by my other keys on the keyring folding over on top of the button, maybe smashing it while en route to or once in my pocket. |
06-02-2022, 02:08 AM | #18 |
Rep 29
Old thread but relevant info.
My trunk has done this 3 times on me and I am pretty sure it's due to the remote being in my pocket and the button inadvertently being pressed. I found this post on bimmerfest forums by Bob Clevenger. I just changed this coding on my car and now the fob trunk button is disabled but comfort opening still works. I did this with BimmerCode I will know within a week if this was the cause of my trunk randomly opening. Here's what he posted: My 2016 340i X-Drive had the same problem. I finally got the coding that stopped it. I used Bimmergeeks ' "Pro Tool" software on my Android phone to do the coding. SAFETY>Fem>Expert>REMOTE_CONTROL>DEFAULT_IDG_3RD_B UTTON_SHORT set data to 0F rather than default. SAFETY>Fem>Expert>REMOTE_CONTROL>DEFAULT_IDG_3RD_B UTTON_MID set data to 0F rather than default. SAFETY>Fem>Expert>REMOTE_CONTROL>DEFAULT_IDG_3RD_B UTTON_LONG set data to 0F rather than default. SAFETY>Fem>Expert>REMOTE_CONTROL_TIME_DELAY_BOOTLI D> set data to FF rather than default. Now the trunk lid stays shut. It will not open with the remote, which I consider a useless feature, but it opens with the button in the cabin and with the sensor pad at the rear of the trunk lid. The lockout switch in the glove box still functions. https://www.bimmerfest.com/threads/t...#post-13600340 |
