03-02-2019, 12:37 PM | #1 |
Rep 9
Poly v belt / fan belt / utility belt / serpentine belt 2013 330d n57t
Just changed the poly v belt on my 2013 330d.
Really straightforward: Remove engine cover, 2 x 10mm plus 1x 30 or 35 torx bolt. This removes cover / sound deadening on the front of the engine. Next, the twin roller tensioner has a 16mm socket on it.(circled in orange) Tighten / rotate clockwise which releases the tension. A hole in the tensioner lines up with a hole in the body (red dots to red dots) I used a T25 torx Allen key as a locking tool to hold it in place. A thin screwdriver would work or Allen key. Then remove the old belt (after taking a photo / drawing a diagram of the path of the belt) Check all the rollers Install new belt, making sure it aligns correctly on the rollers etc. Very slightly tighten the 16mm bit to take the tension off the locking tool. Remove locking tool and very slowly slacken / anticlockwise rotate it to allow the tensioner to tension the belt. Check it is correctly aligned on all the pulleys. Reinstall front cover. Job done. Easy peasy. lemon squeezy Last edited by Mark23rhodes23; 03-04-2019 at 06:27 AM.. |
02-18-2024, 11:40 AM | #2 |
204
Rep 385
Just to add to this thread an image of a recent auxiliary (v) belt change.
Outer side of a belt has not got any cracks or visible wear, but inner side has those grooves to match its counterpart on pulleys and is really worn. Belt is from N47 engine, 12 years old.
1995 E34 525td auto • 2016 F30 320ed auto
02-19-2024, 01:04 PM | #4 | |
204
Rep 385
What's expensive is guessing on what is making a noise; idle pulley, crank pulley, alternator clutch, AC.
02-20-2024, 03:09 AM | #6 | |
794
Rep 1,013
I do have a slight whirring/whine noise which recently developed, and seems to be gradually getting louder. It only happens at idle when the engine is hot. AC on or off makes no difference, so hopefully something cheap like an idler pulley or water pump. |
02-20-2024, 06:23 AM | #8 |
204
Rep 385
120k miles, and this is mostly motorway, no south big city crawling.
Techno 9000518.00 |
