03-02-2019, 03:46 AM | #1 |
409
Rep 1,162
Over the last few weeks my car has developed a fairly significant wobble particularly at higher speeds.
Needless to say the dealer initially offered looking at it in 3 weeks time. Being me off course I decided to look into things a bit more and quite quickly found that the offside front disk was warped. Rather than faff around with the dealer again I just replaced the front disks, pads etc myself. Wobble all gone (as expected) and the car is back to normal. I used Zimmerman disks and pads and replaced the wear sensor and mount bolts at the same time. Total job time took about 90 mins. After I got the offending disk off I measured it up and found that the outer plate had bowed outwards over about 20% of its area by more than 1mm. Which rather explains why the car felt so awful. |
03-02-2019, 06:32 AM | #4 |
2812
Rep 4,935
Drives: 340i MPPSK
Would what the dealer would have made of it (and charged you). Dare say they'd have taken a lot longer than 90 minutes!
Life is a state of mind |
03-02-2019, 07:20 AM | #6 | |
1983
Rep 3,216
If (for example) you drive and brake hard and then sit on the brakes, you will impart a hell of a lot of heat into the contact area between the pad and disk, warping the disk. |
03-02-2019, 03:08 PM | #7 | ||||
409
Rep 1,162
On the other hand I'm very impressed with the one piece Zimmerman disks and pads so far. |
03-04-2019, 10:55 AM | #8 |
470
Rep 785
Drives: 2018 F80 M3 CP YMB
I had a warped rear disc on my last 335d - that seemed pretty unusual to me (to the point that I actually assumed it was a front disc and changed those out expecting to fix it & it didn't) - anyway it meant I changed all of mine out for slotted & dimpled Zimmermann discs & I too can thoroughly recommended them... We have a few fords at the bottom of steep hills in my neck of the woods which never seems a good thing for your brakes - can't say what did cause it though - just one of those things...
