02-28-2019, 04:29 PM | #1 |
163
Rep 216
Hi all,
I'm looking for some advice about a 2017 BMW 440i. The turbo is making a fairly loud whistling sound when it spools and I have major loss of power. Does this mean I have a leak somewhere? The car is still drivable but makes very little power. Thank you! Edit: I have a high flow cat, Dinan intake, and was running jb4 on map 3. MPPSK |
02-28-2019, 09:08 PM | #3 |
163
Rep 216
02-28-2019, 10:34 PM | #5 |
5886
Rep 10,256
02-28-2019, 10:35 PM | #6 | |
163
Rep 216
02-28-2019, 11:06 PM | #7 | ||
54
Rep 202
Drives: 2011 M3 6sp
02-28-2019, 11:20 PM | #9 |
163
Rep 216
My understanding was map 3 was the least aggressive?
Edit: found this from Mike on an earlier b58 post I used as reference. Is this true? "Map Guide as of v4 firmware below: Map 0: Disable JB4 all together Map 1: Suggested performance map Map 2: More aggressive than map1 for bolt on mods and higher octane fuels or octane booster, currently in BETA testing Map 3: Less aggressive than map1 intended for use with lower grade fuels or customers looking for less of a performance increase. Map 4: Stock tuning with CANbus active for logging and diagnostics Map 7: Water/Methanol Injection map" |
03-01-2019, 05:59 AM | #10 |
809
Rep 1,369
Those are old maps. Current maps are 1 is +3 psi, 2 is +4 psi and Map 3 is +6 psi.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
03-01-2019, 06:12 AM | #11 |
163
Rep 216
03-01-2019, 07:04 AM | #12 |
220
Rep 579
Keep us updated
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
03-01-2019, 09:15 AM | #13 | |
120
Rep 410
03-01-2019, 09:21 AM | #14 | ||
163
Rep 216
03-01-2019, 10:47 AM | #15 | |
120
Rep 410
03-08-2019, 09:53 AM | #17 |
163
Rep 216
03-08-2019, 10:13 AM | #18 |
707
Rep 1,170
Can you provide any more details, did they say what caused the failure?
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
03-08-2019, 10:26 AM | #20 |
809
Rep 1,369
8-10k; that’s nuts. If this happened to me out of warranty I’d go Pure Stage 2 for $2250 and pay a BMW Indy $1200 to install it.
fb5830.00 |
03-08-2019, 11:21 AM | #21 |
163
Rep 216
Update:
Bmw is refusing warranty service on the turbo due to "external influences". They're blaming that the Dinan intake is missing a bolt. However; I installed the intake and didn't install the last bolt because I was missing the nut for it. It did not impact the install whatsoever. We'll see what happens now. Edit: Once I explained the situation with the bolt, everything seems okay for now. They're proceeding with the diagnosis. |
BLACK HAWK DOWN105.00 Who's on first2464.00 |
03-08-2019, 02:47 PM | #22 | |
161
Rep 446
Mod bug will bite you if you buy a BMW ================================= |
kern4174449.50 |
