02-27-2019, 05:47 PM | #1 |
Rep 11
Need help locating Air Bag Control module for reset.
Hello guys, I need someone to point me in the right direction. This is my first BMW. I bought it salvaged but in good condition. It's a 2018 430i. I need the location of the SRS/Airbag module. I already replaced the belt tensioners. Air bags look like they've been replaced and I need to reset the module to turn off the SRS light. Thanks in advance!
02-27-2019, 08:47 PM | #2 |
8245
Rep 16,088
You need the use an OBD diagnostic tool with reset capability, like a Foxwell NT510, or some other external means to reset the air bag. There's no way to do it with on board reset tools.
02-27-2019, 09:51 PM | #3 |
Rep 11
Thank you. Yes, I was planning on sending it out to the 'SeatbeltRestore' peeps that did my seatbelt tensioners. They said to take it out and take a pic, then they can let me know if they are able to do the reset on it. I just don't know the exact location in the vehicle and wanted to be sure before I started taking panels off. I don't know where on my vehicle it is located.
02-28-2019, 03:18 AM | #4 |
588
Rep 2,302
02-28-2019, 07:31 AM | #6 | |
8245
Rep 16,088
03-02-2019, 02:45 PM | #7 | |||
Rep 11
03-14-2019, 06:53 PM | #8 |
Rep 11
UPDATE---
I had to pull panels off here and there but I found the issues. Whoever 'worked' on this care before me, simply cut and resealed the Knee Airbag, therefore the 'open' hard code for that. They did the same thing with the pillar airbag. Replaced those 2 and was able to clear those codes. The final code was an open in the circuit for the passenger crash impact sensor. When they wrecked it must have pinned the wiring and they left the wiring hanging. Eventually, the rubbing got the best of the wire and it caused an intermittent short to ground. I still got the code for the BST cable but for now I just went ahead and used a resistor in the connector to get rid of that code. I am missing the front camera and parking sensors and my side cameras are working intermittently now. Anyone knows how to code the warning chime off? Or please drop a link to where I can go and learn how to code that off...I don't have any plans to replace that wiring and camera at this moment. I get that chime everytime I drop below 5mph and it's really annoying. The good thing is that all major lights are off now and I can go to CHP to get my certificate from CHP to register my car. Thanks in advance guys! |
