HOW AND WHY YOU SHOULD BYPASS YOUR BRAKE PAD SENSOR(video)
02-25-2019, 02:12 PM | #1 |
77
Rep 232
Move to different section if this is the wrong place
How and why you should bypass your pad sensor |
02-25-2019, 03:36 PM | #2 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
Nice. I just did this yesterday because the rear sensor CCID came on. The sensor in place is about 2 months old so I'm not sure why it was triggered to begin with. Annoying but I decided to take care of it once and for all this time. Not buying another sensor.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
Black_e9077.00 Jaronbwall284.50 |
02-25-2019, 04:09 PM | #4 |
Is it the shoes!?
3884
Rep 5,112
2mm of pad material is generally a good time to replace them, which is when the light comes on. You don't replace them when they're down to the metal.
02-25-2019, 04:54 PM | #5 | |
77
Rep 232
Also, you don’t have to be a rocket scientist or have a sensor in order to realize when you need new pads, it’s as simple as bending down real fast and looking at the caliper lol. But thanks for your input. |
N54Society448.50 OTO335i144.50 |
02-25-2019, 04:55 PM | #6 |
77
Rep 232
Yeah well mine went off when there was over 70% pad life left so I decided to do this. Much easier and I can reset the light without having to change the pad every time. Like I mentioned in the last post, you don’t need to be a rocket scientist or even need a sensor to know when you need to change your pads.
02-25-2019, 06:56 PM | #7 |
129
Rep 264
While I do agree with your point about not "needing" the sensor, I have to disagree when you say it was setting off the light with 70% pad left. If you indeed had that much pad left, either the sensor was incorrectly installed and was worn through, your inner pads are wearing more than your outer pads or you have an issue with your CBS data. If properly installed, there is no way the sensor can wear through with 70% pad left.
Another note, you can cut the sensor wire a lot closer to the connector so that you don't have all that wiring just wound up behind the fender lining. Props for making the video though. Most people would just say what they want and not put in the effort to show anything. |
8
e90yyc2426.50 TheMidnightNarwhal2664.00 Wolf 3352340.50 Thorin117.50 6ixSpd6018.50 Black_e9077.00 straightcashhomie75.00 Jaronbwall284.50 |
02-25-2019, 07:44 PM | #8 | |
[Oo=||=oO]
1103
Rep 2,470
Most newer BMWs have two stage sensors. Once 1st stage is worn, notification comes on and show brakes need to be replaced in xxx miles (e.g. 3100 miles) and then stay like that forever. Only once the the second stage starts wearing out does the mileage starts dropping below xxxx (3100) and it is very linear. I think the sensor reaches 0 when you still have few mm left. This is for your safety as losing brakes... "...if brakes don't stop you something will..." Like I said... likely user error.. you probably installed the damn thing backwards. But to each its own. |
02-25-2019, 08:59 PM | #9 | |
77
Rep 232
02-26-2019, 06:29 AM | #11 |
2197
Rep 1,322
Yeah I'm not a broke kid so I'll just stick to maintaining my car properly. I've had BMWs for 18 years and haven't had one issue with a brake wear sensor. Being said I replaced them with the brakes and installed them properly.
02-26-2019, 07:43 AM | #12 |
1231
Rep 1,101
A few users have already mentioned this, but pads can wear unevenly. If you're inner brake pad is wearing down faster than the outer pad, it wouldn't be easy to check its wear without either getting under the car or taking the wheel off.
It's worth mentioning that if the pads are not wearing at the same rate, there is probably another issue that needs to be solved (guide pin may need to be lubricated, excessive brake dust build up, etc.). |
Black_e9077.00 |
02-26-2019, 09:22 AM | #13 |
17362
Rep 18,756
You can call people names all you want, but if your pad had only 30% wear when the sensor triggered the notification, then the sensor was loose and got jammed between the pad and the rotor. The sensor would have been FUBAR and it would have been easily discernable that the sensor was not installed correctly.
So what you are saying is not possible if the sensor was installed correctly and the system reset properly at that time. |
02-26-2019, 09:26 AM | #14 | |
17362
Rep 18,756
To OP stated he got the pad light notification and found the pad only 30% spent, which is pretty much impossible. |
02-26-2019, 09:52 AM | #15 | |
2197
Rep 1,322
02-26-2019, 10:10 AM | #16 | |
17362
Rep 18,756
I've owned BMWs for 30 years. All 4 of the BMWs I've owned use pad wear sensors. I still have 3 of cars in my fleet. I've done at least 16 brake jobs over that time. I've never had a faulty pad wear indication. The OP is telling everyone to bypass the brake wear system, which is BAD advice, based on his lack of understanding the system. |
e90yyc2426.50 |
02-26-2019, 11:01 AM | #17 |
449
Rep 1,327
Almost no other car manufacturer over engineers their braking system by putting shitty sensors on them. If it's a safety issue, how are they able to overlook this "grave" matter? A little common sense goes a long way. I've replaced sensors with pads every single time in my BMW cars and 2 out of 5 times something is triggered on the system despite doing a successful reset after the refresh.
Black_e9077.00 |
02-26-2019, 11:16 AM | #18 |
Hoonigan
6852
Rep 3,000
Drives: '09 328i, '98 Wrangler
I've never had an issue with the brake wear sensors. TPMS system is another story.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
02-26-2019, 01:06 PM | #19 | |
2197
Rep 1,322
Pretty much anyone talking about a hack around a designed system to "save you money" is "full of shit." If you dont like spending money on brake pad wear sensors that warn you that you need to do critical maintenance than get what you should have got in the first place, an econobox. |
02-26-2019, 01:35 PM | #20 | |
77
Rep 232
You must have to be a complete air head or not mechanically inclined to not realize when you need new brake pads for your car. You don’t need a sensor to let you know. Which is why I just bypassed it. It makes my life easier. On top of that I’ve dealt with faulty sensors that either break or are innaccurate and tell me I need to change the pads when I’m reality I don’t. I solved the issue to my problem. Anyways, have a good day and thanks for your feedback |
02-26-2019, 01:37 PM | #21 | |
77
Rep 232
Why is everyone so condescending in this forum. We own bmws so it makes sense. I understand how the system works, I’ve just dealt with too many faulty sensors. But thanks for your input |
02-26-2019, 01:38 PM | #22 |
1006
Rep 2,243
Drives: 2007 328i / 2014 M235i
Count me for someone that has shorted the sensor, I own a flashlight and can look in my rims once in a while. Also, when I change my tires, I always have a good look. Both my wear sensors triggered at the same time, when only one was low but I'm still driving on the pads until spring rolls around. Maybe the P.O. tried resetting the indicators before they were changed but when my car light up like a christmas tree, thats when I broke out the soldering iron and am glad I never have to buy, or deal with that indicator as I feel they trigger too early.
Its great for people that never look at their car and drive. Not for me. |
Black_e9077.00 |
