BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Velos ECU Tuning for your F90 M5 via OBD Port
      02-25-2019, 12:38 PM   #1
carlos@velosdesignwerks
Drives: BMW M4
Hello Everyone,
I've been spending a lot of time here on the F90 section with the enthusiasts interested in wheels for their new M’s and have been counting down the days until we could offer our F90 M5 tuning solution to you.
I think everyone can agree, this car out of the box is an animal and with our two solutions I am confident you will enjoy the full potential of your F90. I'll still be in the wheel section for anyone needing more renders, etc but if you have any additional questions on the tuning, traction concerns, etc then let me know!
Feel free to reach me via DM, carlos@velosdesignwerks.com or you can call 786-401-6520 ext. 105 for more details.
By now it is no secret that the BMW F90 M5 is a machine to be reckoned with. Coming from the factory with a claimed 600 hp and 553 torque testing has clearly proven the vehicle is underrated by nearly 100 horsepower. The F90 M5 yields an additional 100+ horsepower over its predecessor the F10 M5 along with an AWD system that also allows the user to change to a RWD mode. This 4.4L family of Twin Turbo motors from BMW has been a joy for our engineering team to work with, a solid platform once you stay within the factory safety parameters with an endless amount of torque the F90 M5 platform proved to be our favorite to date.
In the never-ending quest for additional reliable power our team has produced a Stage 2 Tune that produces peak gains of 135hp and 145 torque on a Competition Package equipped F90 m5. As you can see on the dyno chart below the gains throughout the rpm band are steady at roughly 90hp and 90 tq after the peak torque earlier on in the RPM range and all the way to the peak Horsepower at 5600 rpm. With adjustments to fuel, ignition, limiters and other parameters the results raise this “Family Sedan” to a new level. All changes done well within factory specs with all safety parameters left in tact.
We also have a Stage 1 Available (65-70hp and 80tq) currently with introductory price.
*Note: All dyno runs completed on same day in fifth gear. Final programming done minutes after run in stock form.
*This upgrade works with our Velos Personal Tuner for remote programming worldwide*
Velos Designwerks performance software key features include but are not limited to:
Improved Throttle Response
Re-calibrated settings for a smoother part throttle transitions
Re-calibrated settings for a smoother and more linear power delivery
Raised RPM thresholds (where applicable)
Increased Boost levels
Re-calibrations for end user’s available premium fuel (91/93oct. or 100oct)
Off road only/track use tunes available.
Top Speed Limiter removal
Exhaust burble increase on decal (same as factory sound) / Optional “pops” available.
Dyno Runs:
note* all testing below done on the same day. Vehicle programming done on the dyno (no time for adaptation).
STD Correction:
SAE Correction:
Condition:
Consecutive Runs:
Peak Torque Gains:
Shows max gains (difference) between run in stock form as well as with the Stage 2 Upgrade
      02-25-2019, 01:40 PM   #2
shahin
169
Drives: 18 M5 FE,15 M6 GC, 12 M5,06 M5
Are those at the wheel numbers or crank?
      02-25-2019, 02:20 PM   #3
Drives: BMW M4
Hope all is well, thank you for the question. the peak gains of 135hp and 145 torque are measured at the crank. The dyno charts show the actual peak gains and where they are measured at the wheel. Those gains are ~ 112hp and ~125 tq. The runs are displayed in both STD and SAE for those interested along with the conditions of that day with corresponding fuel across the board. Please let me know if you have any other questions and we are also available via phone at 7864016520
      02-25-2019, 03:28 PM   #4
Steeve19M5CP
194
Drives: 2019 MBB Blue M5 Competition
Why are some previous other dyno's showing stock baseline of 625whp for the F90 M5 and this one 571whp?
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package
2013 Lamborghini Aventador-Pearl Green-Modified
2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified
2018 Range Rover Velar S-White
      02-25-2019, 04:18 PM   #5
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
I'd guess companies using different brand dynos (Mustang, Dynojet, etc) and different conditions (elevation, fuel, temperature, etc).
      02-25-2019, 04:22 PM   #6
Steeve19M5CP
194
no all on Dynojet that I've seen.
example;
      02-25-2019, 04:51 PM   #7
Drives: BMW M4
Noticed on a few other runs and with our friends at IND made 20-25 more on average which makes sense given the different cities, dyno, etc.
The main purpose was to show the before and after in a controlled environment on the same day. A few things are for sure with this Beast is that they consistently pull the same #’s in stock form and tuned, as well as being underrated from factory. We shared conditions and SAE for those interested but I'm sure a 40 degree difference would yield another ~10-15 hp on the conservative side.
      02-25-2019, 05:05 PM   #8
Steeve19M5CP
194
IND Dyno'd 625 wheel horsepower and 608 lb/ft torque oem stock
Ok was just curious if these M5's stock had that much variances in power.....you Dyno'd 586whp stock with STD correction and Burger 619whp on STD correction as well....thats a 34whp difference! and IND 39whp difference
      02-25-2019, 05:27 PM   #9
Drives: BMW M4
Hey,
No worries just trying to show the before and after from that day. They will vary a bit due to the vehicle itself, climate, dyno etc. IND did a few runs in fifth gear 604,607,611,606, and then the fifth run looks like it hit 625 at around 5900 rpm in a mini spike. On these 500+ hp vehicles and without weather being so miserable both vehicles seem to be on par with one another in stock form.
Looking forward to more from this platform and the best part is there is still more room
on the table. Love the Marina Bay btw, something about Blue on an M5 that always gets me (especially with the E39)
      02-26-2019, 09:41 AM   #10
Drives: BMW M4
Hope everyone is doing great. All PM's answered. Have a few introductory slots left. Please feel free to contact me via PM, or call 786-401-6520.
      05-09-2019, 02:24 PM   #11
Drives: BMW M4
Happy Thursday everyone. The weekend is almost here.
All PMs and emails have been responded too. If you have any questions feel free to let me know.
      05-10-2019, 01:52 PM   #12
Drives: BMW M4
TGIF EVERYONE!!!!!
      05-11-2019, 09:49 AM   #13
bm5bullit
bm5bullit's Avatar
Drives: 2021 BMW M340i
Excellent work and, yes, I agree with everything you are saying but the differences due to weather, air density, dynos ....................etc. Just good to know that the pursuit for a 9 second F90 goes on.
2021 M340i
2020 X3 M40i - her car
2019 M5, AW, DP's, MSR CAI, BM3, SOLD
2020 Chev. ZR2 Bison truck, Daily Driver
      05-15-2019, 11:24 AM   #14
Drives: BMW M4
Thank you Thank You
We just received some extra units if you are interested in please contact me via email carlos@velosdesignwerks.com or you can reach me at 786-401-6520.
Have a great day!
      05-16-2019, 02:13 PM   #15
Drives: BMW M4
Thank you Jaymelo238. You will be receiving your handheld soon.
All my PM's have been answered. Any other questions please feel free to contact me.
      05-17-2019, 01:50 PM   #16
Drives: BMW M4
How's everyone doing today???? Happy FRIDAYYYYY!!!
Hit me up if you have any questions here or you can reach me via email carlos@velosdesignwerks.com or you can always feel free to call me at 786-401-6520.
      05-17-2019, 02:45 PM   #17
TrevorM3
3321
Drives: 6.3 AMG
carlos, i think i will be doing my spring install with you guys. Jose with his f90 did his KW by you guys, and you come highly recommended.
Look forward to checking the shop out.
      05-17-2019, 03:07 PM   #18
Drives: BMW M4
Awesome man! Yeah just let me know what day you will be coming in so we can schedule accordingly.
look forward to seeing you.
      05-17-2019, 04:30 PM   #19
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Carlos!!!!!
Take care of T!!!
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      05-18-2019, 07:35 PM   #20
TrevorM3
3321
Drives: 6.3 AMG
      05-20-2019, 12:22 PM   #21
Drives: BMW M4
HAPPY MONDAY!!!!!!!!
How's everyone doing today? Just answered answered some PM's and emails. Will be getting some handhelds in by today if anyone wants to reserve any let me know.
Have a great day!
      05-20-2019, 12:23 PM   #22
Drives: BMW M4
Originally Posted by josec70 View Post
Carlos!!!!!
Take care of T!!!
We will Sir!!!
Search this Thread:
Advanced Search
