BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    M5C racechip dyno results
      02-22-2019, 07:54 PM   #1
rush24
Drives: 2019 M5c
I took the car to a dynojet today. The car has 1250 miles, 80.3 temp, 30.22 humidity and 93 nonethnol gas. The car is completely stock other than a racechip. Still has the charcoal filter in the air box.
Max power 682.3
Max torque 614.69
Appreciate 2
r33_RGSport12967.50
soooma1377.50
      02-22-2019, 07:56 PM   #2
F01Boost
70
Drives: 2012 750i Msport tuned
Max power 682.3
Max torque 614.69
Max power 682.3
Max torque 614.69
Do you have a baseline without the RC
2018 F90 stage 2 dme w Keller performance dp
2018 X5m dme tuned
2015 650 vert dme tuned
2012 750i M Sport JB TUNED- Current
2010 135 vert JB Tuned - retired
      02-22-2019, 07:59 PM   #3
rush24
Drives: 2019 M5c
I do not, sorry
      02-22-2019, 08:08 PM   #4
onfireX5
3619
Drives: F90M5,F85X5M
Very STRONG !
r33_RGSport12967.50
      02-22-2019, 08:41 PM   #5
turbomcgee
75
Drives: 2018 M5
Max power 682.3
Max torque 614.69
Which Map/setting was this?
That smoothing is on 5 correct? when I zoom it gets too grainy for my eyes to fully read
Max numbers are strong...but I'm not liking that power curve if that is on a 5 smoothing, If its on a zero ask them to give you a graph on 5.
Thanks!
      02-22-2019, 08:46 PM   #6
rush24
Drives: 2019 M5c
Yes it does, this was on Race Or highest setting
      02-22-2019, 08:49 PM   #7
turbomcgee
75
Drives: 2018 M5
can you help my eyes and read me the number for the smoothing setting.
Thanks
      02-22-2019, 08:51 PM   #8
rush24
Drives: 2019 M5c
The smoothing setting was 5. The run was in 5th gear
      02-22-2019, 09:04 PM   #9
turbomcgee
75
Drives: 2018 M5
Ok that curve while set on max smoothing is a little odd and all over the place, there seems to be a lot of modulation going on...either throttle, boost, or a dyno issue...etc?
do you have a log? was the car in dyno mode?
a good tune isnt about just peak number, the curve is just as important or more so than peak numbers.
a log would be super beneficially
      02-22-2019, 09:06 PM   #10
Steeve19M5CP
194
Drives: 2019 MBB Blue M5 Competition
Great run.....I have yet to see a dynojet result of a stock M5C for baseline
      02-22-2019, 09:19 PM   #11
rush24
Drives: 2019 M5c
They had trouble with the wire to the coil. The rpm was very jumpy on the screen. they said that was why the torque was all over the place. I did not know the car had a dyno mode.
      02-22-2019, 09:25 PM   #12
turbomcgee
75
Drives: 2018 M5
Ok well thats positive news in this case lol.
The car does have a dyno mode...now whether it makes any real difference IDK. I'm sure it just kills ABS and DSC, but I dont think there is any official documentation on it.
soooma1377.50
      02-22-2019, 09:49 PM   #13
Who's on first
Who's on first's Avatar
Drives: A-10C
Max power 682.3
Max torque 614.69
Max power 682.3
Max torque 614.69
All you had to do was turn the chip off???
Back to back runs. Easy.
      02-22-2019, 10:08 PM   #14
rush24
Drives: 2019 M5c
I will schedule another run soon and turn the chip off. I seriously forgot until they were running the last run.
      02-23-2019, 01:45 AM   #15
shoei
7779
Drives: MW Vespa w/pink racing stripes
I'm not sure what to make of all these tunes and whatnot... This was my stock run, 2018 F90, on glorious 91 octane, inside a mustang dyno... Not compensating for AWD drive train loss...
Custom tune next week or the week after, depending on if I have time and exhaust gets installed... Will run another dyno after...
soooma1377.50
      02-23-2019, 04:11 PM   #16
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
That torque reading seems really high for stock, wheel numbers (especially for a Mustang dyno)--that's what it's showing, though, right?
      02-23-2019, 04:32 PM   #17
shoei
7779
Correct... They did a few runs... And yes, mustang Dyno... 91 octane as well so that also leaves more head scratching... I am at sea level so no elevation...
The torque numbers - that's what I'm confused by comparing it to other people's tuned dyno results...
I'll have them run dyno again before they tune and post results... =/
      02-23-2019, 05:17 PM   #18
Ever34
325
Drives: F90 M5
Is this before the downpipes and the intake?
      02-23-2019, 05:30 PM   #19
shoei
7779
Yeah... Those intakes are more visual and sound mod not performance, that's for sure...
Ever34324.50
      02-25-2019, 01:49 PM   #20
turbomcgee
75
Drives: 2018 M5
its very common for places to configure their mustangs to read similar to DJ numbers. - A shop by me has both a DJ and MD and they read nearly spot on, as they configure it to read that way.
Without knowing all the variables its impossible to know.
CrazyK104.50
      02-25-2019, 05:27 PM   #21
mark5092
mark5092's Avatar
192
Drives: 2019 M5C, 18 M3 ZCP, 20 Raptor
That is exactly the problem, bad connection for rpm pickup. In that case torque value is read from highest jagged point. Not accurate reading.
Takes a dip in horsepower between 105 and 115 mph also. Don’t know what rpm range because units are in mph on bottom of graph instead of rpm.
      03-06-2019, 01:23 PM   #22
subzero05
116
Drives: 2007 335
Max power 682.3
Max torque 614.69
nice, good numbers. where did you get it done/installed at?
