02-22-2019, 08:21 PM | #2 | |
7861
Rep 5,796
Drives: 2024 BMW XM Label
The worst thing that could happen is if the BMW did a software update while your car was in service you might have to redo everything you coded. |
boonkgang13k54.50 gilbo213.50 |
02-22-2019, 09:36 PM | #3 | ||||
55
Rep 60
VirtualGuitars7860.50 |
02-22-2019, 10:19 PM | #4 | |||||
7861
Rep 5,796
boonkgang13k54.50 |
02-23-2019, 06:57 AM | #5 |
1115
Rep 2,072
Wait - Bimmercode can do this? I have BC but haven't used it in over a year. I'm guessing they've finally updated it. I'll play with it today.
02-23-2019, 07:02 AM | #6 |
7861
Rep 5,796
It has really evolved. As of just a few minutes ago, the ODBLink MX+ adapter is now supported on iOS too. This is good news since I already had one of those before. I still prefer my UniCarScan since it supports all of BimmerCode's features.
02-23-2019, 04:04 PM | #7 |
33
Rep 45
Curious if you use bimmercode with the engine on for the basic coding or with just the ignition on? I've used e-sys on my f10 back in 2016 with the engine on just to avoid any loss in connection or voltage dips during coding.
02-23-2019, 10:34 PM | #9 | |
7861
Rep 5,796
reesch33.00 |
02-24-2019, 06:34 AM | #10 |
1115
Rep 2,072
I must admit, I never code that - I did the instrument cluster & HU with the engine running. I actually wanted to do the ambient lighting but I need a different adaptor to the front electric module - the VGate I have is no longer supported (but still works for some modules).
02-24-2019, 07:34 AM | #11 |
208
Rep 328
When I read the directions I knew the car needed to be off and then push the start button 3 times with out pushing the brake. Then I would be in diagnostic. I am sure there is a purpose doing it this way most likely so you dont end up with a giant brick.
2018 540i
2019 X5 xDrive40i 2012 Boss 302 #2147 2017 Shelby GT350 2017 F250 KR |
02-24-2019, 09:34 AM | #12 |
7861
Rep 5,796
I have done quite a bit of coding with this app, and I've only had to go into diagnostic mode for the engine control unit. All of the others were fine with the engine running. I think it was for the Auto/Start/Stop.
reesch33.00 |
02-24-2019, 10:20 AM | #13 | ||
55
Rep 60
02-24-2019, 10:28 AM | #14 | |||
7861
Rep 5,796
boonkgang13k54.50 |
02-27-2019, 03:13 PM | #15 |
4446
Rep 7,487
Can you just hook up a battery charger/tender to the jump start terminals in the engine bay to prevent bricking any modules by a loss of power? That way you don't have to start the engine (unless it is a requirement) to code multiple modules that may take a while...and you don't want your battery voltage to drop.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
02-27-2019, 03:30 PM | #16 | |
7861
Rep 5,796
The only one you have to be in diagnostic mode for is the engine control unit. All of the rest can be done with the engine running. |
clee1982797.50 |
02-27-2019, 04:19 PM | #17 |
4446
Rep 7,487
Thanks
02-27-2019, 07:37 PM | #18 | |
376
Rep 1,223
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
02-28-2019, 05:39 PM | #19 | |
169
Rep 195
Drives: 2019 540i xDrive
02-28-2019, 05:46 PM | #20 | ||
7861
Rep 5,796
03-01-2019, 04:16 AM | #21 | |
1115
Rep 2,072
You can set the car to keep the 'comfort' display even when the car is in sport mode via the menu in the car; you don't need to code that. |
03-01-2019, 05:05 AM | #22 | ||
169
Rep 195
