02-20-2019, 11:53 AM | #1 |
Rep 27
Underseat subs
So from what I've read in the past, Earthquake SWS 8x seems to be the go-to option for underseat midbass woofers. This is, of course, assuming that no boot "real" sub is going to be installed.
I have booked my car in next week to have the base audio system upgraded to Focal es100k k2 components and a JL audio xd400 v2 amplifier. I'm keeping the OE look by adding HiFi tweeter moldings. The next stage will be to sort out the bass. I'm debating whether to go with the tried and tested Earthquake SWS or the Audison APBMW S8-4, which are recommended by a well known reputable installer. What I would like to know is from an acoustical engineering perspective what is the better speaker at reproducing bass frequencies? I would like an objective (non-biased) opinion based on the acoustical datasheets of each driver. Earthquake SWS: Size: 8" high performance sub Fs: 20-300Hz Max Power: 300W RMS Power: 150W Impedance: 4Ω Sensitivity: 86.7dB Qes: 1.372 Qms: 3.158 Qts: 0.957 Rvc= 3.400 Ohm Sd=22.000m M² Md= 50.000g BL=5.837 T-M No= 0.086% SPLo= 81.4 dB Vas= 716.361m Ft3 Cms= 295.150u M/N Krm= 4.722m Ohm Erm= 0.687 Mms= 55.805g Mmd= 53.929m Kg Kxm= 204.955m H Exm= 0.257 APBMW S8-4: Component Woofer Size mm (in.) 200 (8) Power Handling 300 W peak 150 W continuous Impedance Ω 4 Frequency Response Hz 35 ÷ 500 Magnet size D x d x h mm (in.) 48 (1.89) x 18 (0.71) x 7 (0.28) Weight of one speaker kg (lb.) 1,21 (2.67) Voice Coil Ø mm (in.) 50 (2) ELECTRO-ACOUSTIC PARAMETERS D mm 159 Xmax mm ±7 Re Ω 3,8 Fs Hz 40 Le mH 0,6 Vas I 21 Mms g 43 Cms mm/N 0,38 BL T•m 6 Qts 0,72 Qes 1,14 Qms 2 Spl dB 88 I'm not an acoustical engineer by any stretch of the imagination but appreciate high-quality sound and do not understand the parameters detailing above, other than power ratings etc. Any help would be appreciated as I may just go the whole hog on Monday coming! |
02-20-2019, 12:01 PM | #2 |
66
Rep 193
Drives: 2012 328i Glacier Silver
I've heard good things about both. When I was getting my BAVSound speakers installed the installer said that the Earthquakes delivered deeper bass. He didn't have one that I could listen to. I'm still satisfied with my BAVSound system.
However, for the Audison, I have their 10" subwoofer box in my truck and it totally blows my truck away. The bass and quality is amazing. I bet those APBMW S8-4 speakers would be just as good sound and quality-wise.
2012 328i Sedan - Glacier Silver - 18" Toyo Proxes 4 Plus Tires with Nürburgring Metal Grey Rims, H&R Sport Springs, VRSF Intercooler, JB+, aFe Air Filter, Magnaflow Exhaust, Carbon Fiber accents, SS Pedals, Bavsound System, BMW CCA member since 2015. First Bimmer - 2000 Z3 M. Second Bimmer - 2014 X1 sDrive28.
02-20-2019, 12:34 PM | #3 |
Rep 27
Thanks! It's good to know I'm likely going to be satisfied which ever I pick.
Hoping to see if there is a scientific advantage to one of them. If not, it will be down to which is the cheapest and easiest to install! I know a boot sub will be better ultimately, but I can't lose the space atm. |
02-20-2019, 12:40 PM | #4 |
8264
Rep 16,111
This is the response of the original OEM BMW hi-fi woofer and the others in the same enclosure with the same amp, same drive level, in this case 1.5 volts:
All three are almost identical in the lows below 50Hz. However, most bass content is between 50 and 120Hz, and in that range the BMW driver is decidedly louder. If you're not upgrading the amp the BMW driver is the best of the bunch. This chart shows the maximum output of those same drivers, which takes into consideration both their electrical and mechanical power limits: From 70-120Hz the BMW driver remains the loudest. Below 70Hz the BMW and Audison are the same, so there's nothing to be gained from switching to the Audison driver. Below 70Hz the Earthquake is considerably better. However, you won't get that additional output unless you have an upgraded amp that can deliver at least 150 watts per woofer. This is the type of data comparison that professional audio engineers like myself use to decide on drivers for their projects. I would not invest in any replacement driver, be it a woofer, midbass or tweeter, where I could not do a similar comparison. That requires having the full Thiele/Small specs on the drivers. Luckily for the OP they're available for the Earthquake and Audison drivers, while I measured the specs for the BMW driver myself. Most after market drivers don't list Thiele/Small specs. |
02-20-2019, 01:19 PM | #5 |
Rep 27
That's extremely interesting and useful Billfitz, thanks.
I just want to make 100% sure that your simulated frequency response applies to base systems as well as HiFi systens that are friends in the US get. The base system has a smaller 6" mid bass driver than the HiFi from what I've read and seen online. Your graphs would then indicate that my new amp is underpowered to get the extra benefit from the earthquakes opposed to stock drivers. Unless, I bridge the amp and power only the earthquakes. Which means I need another amp to power the focals or to choose another... Looks like I will see what improvement the 75w RMS brings to the stock driver and make a decision then... |
02-20-2019, 01:39 PM | #6 |
66
Rep 193
Right, the amp(s) will make all the difference.
02-20-2019, 03:52 PM | #7 |
8264
Rep 16,111
The Euro/UK bass systems use 6.5 inch woofers, so the results I've shown with the 8 inch OEM hi-fi woofer don't apply. The base system is seriously under powered, so even just an moderately powerful separate amp would make a major difference. The woofers you listed are 8 inch, my assumption is that they won't fit the 6.5 inch enclosures.
02-20-2019, 03:54 PM | #8 | |
1166
Rep 2,180
The OEM HiFi woofer response in the above chart does not apply to your Stereo system -those are 8" woofers of completely different construction and response compared to the 6.3" of the Stereo system.
SWS-8 are true sub woofers, the S8-4 are woofers. The SWS-8 will be the closest to a trunk subwoofer that you will get without the trunk subwoofer. What lacks in midbass response -which it is not that much in real life- it makes it up in the sub frequencies. The S8-4 woofers are strong midbass drivers that require a trunk sub to cover the below 40Hz response without distortion. For your XD amp, SWS-8Xi (2ohms) will perform better than the SW-8X(4ohms). SWS-8 will also fit the best in the underseat OEM enclosures, while the S-8-4 will require a 0.50" spacer to fit -and the OEM grilles cannot be fitted after install. Search and you will find plenty of installs details on these two drivers. Quote:
02-21-2019, 05:56 AM | #9 |
Rep 27
I'm going to go with the SWS 8, however as I'm using the amp for driving the front focals, I think it's best to get the 4 ohm version ? to keep them wired in stereo and impedance matched...
02-21-2019, 06:44 AM | #10 | |
1166
Rep 2,180
The best and most effective use of this XD, and any 4ch aftermarket amp, in the Stereo system improvement is to power the front channels with CH1/CH2, and woofers with CH3/CH4 of the XD, and keeping the rear channels powered by the iDrive unit. Then adjust crossovers and gain front/woofers in the XD to taste. That is exactly what BMW does with their own Alpine OEM retrofit kit, just because it works. |
02-21-2019, 07:39 AM | #11 |
8264
Rep 16,111
That depends on your amp and peripherals. The woofers and midbasses should be separately amplified, with the woofer amp inputs low passed and the midbass amp inputs high passed. The last thing you want to do is to drive the woofers and midbasses with the same amp channel. There's no reason to run the woofers in stereo, as the left/right channel signal content below 100Hz is the same anyway.
02-21-2019, 08:20 AM | #12 | |
Rep 27
The focals are 4 ohm. So I assume I have to get the SWS 8x rather than the 8xi. |
02-21-2019, 09:17 AM | #13 |
1166
Rep 2,180
All XD are stable down to 2ohms - 2ch can be 4ohms and the other 2ch can be 2ohms. Your planned system calls for a pair of Xi for best bass effect -SWS-8 are not efficient.
02-21-2019, 09:20 AM | #14 |
8264
Rep 16,111
The difference in the impedance of the midbasses and woofers doesn't matter if they're not being driven by the same amp channel, assuming each amp channel has its own input sensitivity control. Normally one uses the lowest impedance driver that the amp channel is rated for, though that doesn't necessarily make much difference in the end result. In your case with only 75w into 4 ohm capability I would use 4 ohm drivers all around. The problem I see is driving the rear door speakers. I'd be using a six channel amp.
02-21-2019, 12:10 PM | #15 | |
Rep 27
The SWS 8xi will be ordered once I assess the performance of my 1st upgrades( Focals, XD400 v2, front door sound-deading) The rear speakers will remain powered by the HU. They're high-pass filtered I believe. I've been told with my install and the subsequent Earthquakes, I can leave the rears alone. Starting to understand this minefield I think..thanks. |
02-21-2019, 12:30 PM | #16 | |
8264
Rep 16,111
Only if you have 2 ohm drivers.
02-21-2019, 12:39 PM | #17 | |
Rep 27
Yes, the Earthquake SWS 8xi are 2 ohm:
8" High-performance shallow sub Power handling: 150 Watts RMS (300 Watts MAX) 2-Ohm High-temperature voice coil with heat-sink attachment NOMEX/ROMEX spider assembly Aluminum bobbin Protected by 3 U.S. Patents Mounting depth: 2-1/16" Quote:
The rears are high passed I've read, as part of the heavy EQ tuning the base system has - an attempt to compensate for the lack of tweeters. Last edited by 430MAGIC; 02-21-2019 at 12:45 PM.. |
02-21-2019, 12:59 PM | #18 |
8264
Rep 16,111
Considering the low sensitivity of the Earthquakes going with 2 ohms is a good idea. I don't think the base HU EQ could be all that much, especially in the bass. EQ eats up power like mad. Every 3dB of boost doubles the power demands on the amp, and the base HU doesn't have much power to begin with. I can't even say if the EQ in the hi-fi and other options takes place in the HU or in the amp, again because there just isn't any technical data out there. I do know that the hi-fi HU is sourced from Harmon, because I saw the Harmon label on it when I had the dash panel off to vinyl wrap it.
02-21-2019, 04:37 PM | #19 | |||
118
Rep 178
Note that the front 6.5 underseat and the door mid are paralleled on the front channels. Quote:
02-21-2019, 05:14 PM | #20 |
118
Rep 178
Also, I never trust published T/S data. I don't know where those T/S params came from in the OP. The Earthquake numbers were clearly tested by someone (but those are for the 4 ohm 8X, I've pasted the 2 ohm 8Xi below). The Audison numbers look like published data. To be fair I'd trust numbers from Audison alot more than anything from Earthquake (those guys are...disreputable, to put it mildly). We've done extensive testing of most of the available underseats, I've got T/S params for most of them if anyone is interested. What Billfitz says is absolutely correct though, none of the aftermarket woofers will outperform the OEM woofer in terms of efficiency. You can read between the lines for what that means in terms of all the companies selling underseat woofers they claim are louder than the OEM woofers with the factory amp. Physics > Marketing, at least as far as I'm concerned. There is a fundamental trade-off between bandwidth and efficiency - for a given set of constraints, you can play low or you can play loud or somewhere between the two. You can't maximize both. The OEM woofers are crap quality, BUT they are well engineered in terms of being optimized for efficiency.
Also - and I can't stress this enough - T/S params only tell you one thing: they describe the behavior of a driver around it's resonance frequency, i.e. what the roll off of the driver looks like at low frequencies. That's it. They will tell you about the character of the sound at low frequencies, but nothing about the quality of the sound (apart from the freq response portion). Earthquake SWS 8xi D 188.0 [mm] Re 1.85 [Ohms] Fs 43.07 [Hz] Zm 14.53 [Ohms] BL 6.47 [T/M] Qms 7.038 Qes 1.025 Qts 0.894 Vas 17.200 [liters] L10k 0.28 [mH] n0 0.13 [%] dBSPL 83.17[1W/1m] Ms 85.93 [grams] Cms 0.16 [mm/N] Last edited by Kevin @ Integral Audio; 02-21-2019 at 05:23 PM.. |
02-21-2019, 09:14 PM | #21 | ||
8264
Rep 16,111
02-22-2019, 02:26 AM | #22 | |
Rep 27
This would eliminate the need to retune via an expensive DSP (Audison Bit ten) - albeit without other benefits like time alignment etc. I'm thinking a flat input signal to the amp would make for more accurate sound reproduction. The crossovers for the front Focal tweeters are set to reduce the output (without DSP fitted) otherwise the EQ would be too much (something along them lines). Most importantly, coding is a lot cheaper! |
