02-18-2019, 04:29 PM | #1 |
Rep 62
Help me decide - Lowering springs..eibachs?
330d m sport rwd
Not looking for a super drop, just a stance to get rid of wheel gap without ruining the ride quality... I've been told eibach 25mm Is the way forward, opinions? |
02-18-2019, 04:39 PM | #2 |
10995
Rep 32,881
I’ve just bought Eibachs for the X3, ACS have priced themselves out of the market, they wanted £494 for X3 springs! Got the Eibachs for £140 from Autodoc!
Only potential problem I can see with the Eibachs for your car is they lower about 10-15mm more than ACS, 35-40mm apparently: https://www.autodoc.co.uk/eibach/7016664 Last edited by teaston; 02-18-2019 at 06:38 PM.. |
02-18-2019, 04:55 PM | #3 |
463
Rep 1,049
Drives: F31 320D Xdrive Msport+
iirc are there not two spring options with eibach which give two different levels of drop? Or am I mistaking them with another brand.
Just looked this up on eibachs site it is then with the two levels of kit there's SPORTLINE | Sport Performance Springs Extreme Performance Meets Extreme Style Race-Car Like Handling Lower than our Pro-Kit. Lowers Vehicle 1.7" - 2.3" (50 mm) Progressive Spring Design for Excellent Ride Quality Part of the Eibach B12 Sportline And there's PRO-KIT | Performance Springs #1 Choice of Automotive Enthusiasts Worldwide! World's leading Performance Suspension Spring System Engineered and tested to work perfectly with stock dampers First step towards a complete sport suspension system Lower center of gravity – lowers vehicle up to 40 mm Lowering = Traction + Attraction Progressive spring design Performance handling So 40-50mm depending which one always though the less extreme was 30mm not up to 40mm What's the ACS spring drop?
[url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Click here for the Bimmerpost UK Refugees - Censorship Sucks![/url]
02-18-2019, 06:40 PM | #4 |
67
Rep 193
Also worth bearing in mind (i think) that if you have or plan to have certain low profile 20" tyres/rims and spacers, the lower of the two eibachs will limit your options, being too low
02-18-2019, 06:44 PM | #5 | |
10995
Rep 32,881
http://web2.carparts-cat.com/default...4279004&12=130 They don’t list the sportline ones. ACS is 15mm on M Sport |
02-18-2019, 09:22 PM | #6 |
2466
Rep 5,457
Drives: F30
AC Schnitzer
Shop around. Worst case... I can buy for $300 USD and ship to you if you cant find cheaper in UK |
02-19-2019, 03:23 AM | #8 |
101
Rep 322
I've recently fitted Eibach to my 340i along with eibach spacers. All bought from Autodoc. Best and cheapest place to get them.
I confirmed all part numbers through Eibach website. Having adaptive dampers and already slightly lower than "stock" with the m-sport springs, the eibach dropped the front 20mm and rear 17mm. Still only covered about 100miles since fitment, so giving it a bit more before confirming final drop. I did look at ACS springs, but they were just too expensive when I could get the Eibach's for around £150. |
02-19-2019, 05:37 AM | #10 | |
840
Rep 1,993
Drives: F30 335d
Compared to my 335d the e91 was more comfortable over rough surfaces, which I find the 335d struggles to deal with. In fact I'm currently awaiting a B12 kit which will go on the 335d.
if I've helped - an Appreciate would be, er, very appreciated!
