F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6wb coding problem encountered
Extreme Powerhouse
      02-18-2019, 06:52 AM   #1
scoopy
60
Drives: f30 320d
Hi i bought a bnew 6wb cluster and i was able to install it and was able to start the car and i got error in the cluster which are i attached in the pic. So next what i did i hook up my computer and i will code it. However, i got an error message when i saved the option 6wb and when i tick the FA for calculate fp i got this message
Can someone please help me? Or tell me what should u do? O tried changing the pszdata however when i tried my computer it doesnt want to connect and there were error messages in the computer so i put it back and esys is working again
      02-18-2019, 09:12 AM   #2
atzebmw
Germany
588
Drives: Tesla Model 3
I see 2 problems.
You are using EsysPlus which is only supported up to 2015.
So EsysPlus doesn‘t know the 6WB.
And then your „Zeitkriterium“.
The 6WB wasn‘t yet available in 2013.
I would now try the following.
Start Esys direct without EsysPlus.
For changing the VO and coding you don‘t need EsysPlus.
And then change the „Zeitkriterium“ to 0717 where the 6WB was available.
      02-18-2019, 09:35 AM   #3
scoopy
60
Drives: f30 320d
Originally Posted by atzebmw View Post
I see 2 problems.
Ok if i have esys direct does that mean i need to update the pszdata?
      02-18-2019, 11:34 AM   #4
scoopy
60
Drives: f30 320d
I see 2 problems.
So EsysPlus doesn't know the 6WB.
And then your "Zeitkriterium".
The 6WB wasn't yet available in 2013.
For changing the VO and coding you don't need EsysPlus.
And then change the "Zeitkriterium" to 0717 where the 6WB was available.
Was able to change the date to 0717 and was able to put 6wb however after i coded my HU_entry when i look back dkombi was not there anymore.
f30post
