BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs)    Ceramic coating wheels and wheel weights
      02-13-2019, 08:04 PM   #1
Docflyer
Drives: M5 2019
I’ve ordered new wheels for my incoming M5. Also I’ve ordered Kamikaze Stance coating to apply to them. I would love to apply the coating prior to mounting, with rims spotless and no tire in the way. However I’ve read conflicting advice in regards to how well the wheel weights will adhere on top of a coating with balancing.
Does anybody have experience or advice regarding this ?
It also so seems to me it is very likely you may rebalancing a set of replacement tires prior to a coating wearing off anyway.
      02-14-2019, 12:23 PM   #2
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
I would just apply with wheels on .... BMW brake dust is a bitch ... ceramic coating will only do so much. Easier to clean but wheels will still get dirty fast.
Replacing the pads is the only solution that really works.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      02-14-2019, 01:07 PM   #3
Docflyer
Drives: M5 2019
Thank you jocec70. Hope alternate break pads available soon if not too costly.
Will probably give wheel coating a try if just to make them somewhat easier to clean. Treating the new clean wheels out of a box would just be hard to pass on.
Have been impressed with the results I've had on the body with Gyeon Mohs. Granted break dust a whole different animal.
      02-27-2019, 10:18 AM   #4
ACF90M5
ACF90M5's Avatar
21
Drives: 2018 F90 M5
I have had my wheels coated on multiple cars and never had an issue with the wheels balances not sticking. However, if the wheel is being balanced during the curing process (48-72 hours of no water typically) then I guess I can see that happening
2018 BMW M5 Black Sapphire Metallic
GONE - 2013 Audi S6 Phantom Black Pearl
      02-28-2019, 10:54 AM   #5
Docflyer
Drives: M5 2019
ACF90M5 Thanks for input. New wheels coming this week and I plan to coat them with Stance Rim Coat prior to mounting. My M5 is on boat now according to BMW Garage. Hopefully here soon...
      04-08-2019, 01:22 PM   #6
Docflyer
Drives: M5 2019
Update on this topic. Don't ceramic coat your rims prior to mounting the tires. The weights absolutely wont adhere well.
      05-02-2019, 10:01 AM   #7
Yoshimura
Yoshimura's Avatar
Switzerland
16
Drives: BMW 650i xd in order BMW M5 C,
Thanks for this precious update. Did you use Kamikaze Stance Rim Coat?
      05-02-2019, 12:46 PM   #8
Docflyer
Drives: M5 2019
Yes I did. I applied a Myobi base coat then a Stance top coat.
On re-balancing wheels we had to buff the areas with a polisher to get the weights to adhere. I basically copied Esoteric's recommendation in this YouTube video.
      05-02-2019, 12:52 PM   #9
kdeleon
94
Drives: M5
I used Gyeon Rim on new wheels before I mounted my tires. I have had no issues with the weights sticking.
      05-02-2019, 01:45 PM   #10
Docflyer
Drives: M5 2019
Mine initially adhered but a few of them washed off with a pressure washer so i decided to re-do all of them.
      05-18-2019, 01:23 PM   #11
kdeleon
94
Drives: M5
So I have now done several washes with a pressure washer and agitation with a brush. My weights are all there.
Search this Thread:
Advanced Search
