02-19-2019, 05:54 PM | #45 | |
194
Rep 459
"1. Material: Stainless Steel and Carbon Fiber 2.Carbon Tips Size(OUTLET): 90mm(3.5inch) 3. Stainless Tips Size(INLET):70mm-78mm(2.75-3inch) 4.Fitment: For universal cars, please check size before order 5.This is exhaust tip only, would not make sound or any smog problems 6.Professional installation is required(may a clamp on installation, welding may or not required" Keep us posted on the Mperformance tip fitment
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package 2013 Lamborghini Aventador-Pearl Green-Modified 2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White Last edited by Steeve19M5CP; 02-19-2019 at 05:59 PM.. |
02-26-2019, 03:19 PM | #46 |
200
Rep 292
Tips arrived today, Not even close to fitting as intended with supplied clamp. The diameter of stock exhaust end is too big, Welding them on makes sense anyway, can you imagine having them stolen.
2019 MBB/Aragon M5C M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp Last edited by MCOMP; 02-26-2019 at 06:35 PM.. |
02-26-2019, 03:33 PM | #47 |
1716
Rep 1,909
Drives: 2023 M5C
02-26-2019, 08:29 PM | #48 |
123
Rep 353
Thanks! So the tip size remains the same as that on the F80 M3. No M Performance exhaust tip has ever been designed to fit, no difference here. This is the first time you can't cut the outlets of the exhaust either as they are wider than any of of the inlets in these tips. Thanks for sharing.
02-26-2019, 08:50 PM | #49 | |
200
Rep 292
2019 MBB/Aragon M5C M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp |
02-27-2019, 08:24 AM | #50 |
194
Rep 459
how wide is the diameter of the comp pipe exactly? what minimum size diameter is needed to have a clamp on tip inserted?
2017 BMW 330i - Estoril Blue - M Sport Package 2013 Lamborghini Aventador-Pearl Green-Modified 2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
02-27-2019, 08:57 PM | #52 |
200
Rep 292
Shop did a thorough job. About 2 hours labor.
02-27-2019, 11:35 PM | #53 |
123
Rep 353
02-28-2019, 05:17 AM | #54 | |
200
Rep 292
The supplied clamp is used to keep it in place but a few spot welds were added for security.
elbmw812.50 |
02-28-2019, 05:24 AM | #55 | ||
4074
Rep 5,233
03-01-2019, 09:34 AM | #58 |
194
Rep 459
Looks good which shop did you use?
03-03-2019, 05:27 PM | #59 |
200
Rep 292
04-21-2021, 02:27 PM | #60 |
146
Rep 898
Drives: F90 M5
Just reviving this thread in case anyone is interested - there are now eBay listings for M Performance style tips that fit over the standard F90 exhaust diameter out of the box. Just put a set on mine and am pleasantly surprised by the outcome!
I wish they sold the actual M Performance exhaust here in the UK, but these will do for now.
F90 M5 (Marina Bay Blue, M Performance Parts)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i |
04-21-2021, 06:28 PM | #61 | |
195
Rep 612
04-22-2021, 02:51 AM | #62 |
146
Rep 898
Drives: F90 M5
https://www.ebay.co.uk/itm/274642483602
That's the one I got. One thing to note: you do have to grind off the exhaust pin to fit the tips. The listing says it's optional but it's not, the grub screw does not fully hit the exhaust with the pins in place.
04-22-2021, 02:53 AM | #63 | |
11
Rep 44
