Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Steering lock problem (E90)
      07-22-2008, 02:25 AM   #1
BMdriver
Bus Media, Xenons, Spt Auto, Sun Pro Black Panel
United Kingdom
41
Drives: 420i M Sport Coupe (Pro pack)
The steering lock and padlock symbol (amber and red) has displayed in my car along with an audible clicking from the steering column, and failures to start. New software has failed to cure this. Has anybody else experienced such a problem, if so what was the cure. Since the new software load the dealer says error codes are still found, but no fault is apparent. Any advice would be most appreciated.
      07-22-2008, 02:32 AM   #2
jmlcrm
Drives: 06 E90 325I, 06 E46 325CI
Had this happen on my car... Took it into the dealership and they said that when the car was manufactured, there were a set of steering mechanisms thay were prone to this problem... Kept the car for about 2 or 3 days and replaced some of the steering components... Been going strong ever since...
      07-22-2008, 02:33 AM   #3
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
It's a fault with the column and it will most likely happen again, it needs replacing under warranty, I had mine doe earlier this year.
      07-22-2008, 03:13 AM   #4
andy69
andy69's Avatar
13
Drives: E90-320d
I've been getting this as well recently..mines booked in this Friday to get the brake pad warning looked at as well.
Hope they sort it as the warranty runs out next month
      07-22-2008, 03:59 AM   #5
PhilR
PhilR's Avatar
United Kingdom
9
Drives: E93 330d M Sport Auto
Happened to me for the first time last week. Amber warning light and car wouldn't start with some steering lock malfunction message. Removed and replaced fob and OK then?
Think I parked without straightening the front wheels though - something I wouldn't normally do.
If it happens again I'll contact the Dealer
      07-22-2008, 04:23 AM   #6
BMdriver
United Kingdom
41
Thanks guys for your help. The car is at the dealer today. I suspect a new column will be the cure since new software has failed to cure the problem. If so - is it a major dashboard pulled apart job, or is the change less evasive? (I fear the parts never fit back as well as it fitted in the factory).Also will the wheel alignment etc be effected and require resetting in the dealer or will this remain unchanged?
For info - the car has driven and pulled through the gears much better since a new version of software was loaded.
      07-22-2008, 04:57 AM   #7
creepy coupe
1867
2009 335i  [0.00]
My dealer estimated 4 hours to do mine, apart from a dirty footprint on the seal and the driver seat being right back,I didn't know they had touched the car.
Deffo not the dash out.
      07-22-2008, 01:43 PM   #8
LRS
Dead Head
LRS's Avatar
United Kingdom
45
Drives: E92 335d Coupe
Location: (Then > Bay Area, Calif) (Now > Southeast, UK)
Had the same thing happen about 6 weeks ago. Replaced the battery in the key fob. All OK at the moment.
I guess time will tell...
E92 335d SE Auto | Space Grey | Black Leather | 19” 230 Star Spoke | Comfort Access | Lumbar | Heated Seats | Black High Gloss Trim | Pro Nav | Assist | Bluetooth Telematics | Voice Control | High Gloss Shadow Line
      07-22-2008, 01:45 PM   #9
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Mine had this, had the car a day to re-code, it went away for few weeks then came back. They changed the whole column.
997.2 GT3
      07-22-2008, 01:50 PM   #10
InS0mNiAc
InS0mNiAc's Avatar
9
Drives: 2007 E90 335I Montego Blue
Happened once, hasn't happened again though....
Oil Cooler retrofitted by BMW......now it's on...
      07-22-2008, 04:48 PM   #11
pinman
Drives: BMW 330i M Sport
Same story here, stealer did the software download that don't work, so they
had it back (gave me a 5 series for the day, didn't like it), and the new
coloum was fitted by 2pm.
Been fine since.
Gazza
      07-22-2008, 05:42 PM   #12
mgarvey
mgarvey's Avatar
United Kingdom
30
Drives: Renault Megane
I've got this too, dealer updated software and the error message has gone away but the clicking noise came back within days.
They also fixed the noisy rear seatbelt mechanism problem and that has come back too.
Looks like it is going back in again (sigh).
      07-23-2008, 05:35 AM   #13
dxb335d
dxb335d's Avatar
England
949
Drives: 997.2 GT3
I never had a clicking noise with it.
997.2 GT3
      07-23-2008, 06:47 AM   #14
alcook
alcook's Avatar
United Kingdom
22
Drives: M4 CP Convertible
This happens 2-3 times a week for me. I put it down to the fact that the mechanical aspects of the column being released (it does release as I can turn it) are not being picked up properly by the iDrive and I simply pull the fob out and pop it back in.. Cures it everytime.
Most cars I've had have always had a steering lock issue where you have to pull the wheel about a bit and waggle the key to ease the pressure on the lock. I also thought that this could be down to the fact that I turn the car off with slight lock and once off the brakes after slotting P the car moves forward (or back) slightly causing the column to be under a little more pressure.
I hadn't considered it a fault or major issue (just an anomaly of the way the cars locks the column)...
I may give them a call and see if it can be looked at under warranty (as I fancy the software upgrade too.... ).
      07-23-2008, 02:18 PM   #15
coodem
18
Drives: M335d
How do you change the battery, I thought they were sealed units?
      07-23-2008, 03:59 PM   #16
crowdedhouse
crowdedhouse's Avatar
Ireland
70
Drives: 2021 G20 330d mSport
Convenient Access equipped cars' fobs have replaceable batteries..as I think you don't have to have it in the dash to drive.
Seven Worlds Will Collide
      07-27-2008, 04:30 PM   #17
andy69
andy69's Avatar
13
Drives: E90-320d
Mine went in Friday to check out the steering lock problem, all they did was reset the OBC.....so lets see what happens this week
I also had a brake pad warning come up once a few weeks ago although plenty of kms left on all of them so maybe the reset has cured that also....
      07-27-2008, 05:08 PM   #18
mgarvey
mgarvey's Avatar
United Kingdom
30
My problem does seem to be somehow key related. When I use the fob that I had when I had the software refreshed the problem virtually never occurs, when I use the other key it happens quite a lot.
      07-28-2008, 03:20 PM   #19
SoYank
SoYank's Avatar
Drives: 2009 E90 335i MT
Mine had the yellow and the red warnings along with the ratchet-like clicking. I took it in and the SA said it needed attention as soon as possible because it was a safety issue. They replaced a sensor within the steering system. They also updated the software for a separate issue at the same time (well, within the same day at least).
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7
European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor
Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269
      07-28-2008, 04:21 PM   #20
dxb335d
dxb335d's Avatar
England
949
Drives: 997.2 GT3
I did a trackday with my ''dodgy'' column LOL
I booked it in the day before to be checked, told them had a long journey the next day so needed to know it was ''safe''
He said he cant garuntee anything, i said,
''YOU cant let me drive my car out of here on that statement mate, If it aint safe, it dont leave your workshop. Its on your head if i have an accident..... cars dont leave workshops if they aint fit to drive''
He made a call to the workshop then told me ''it will be fine'' LOL
What a Knobber.
997.2 GT3
      08-25-2008, 02:34 AM   #21
andy69
andy69's Avatar
13
Drives: E90-320d
i havent had the 'padlock' fault indicator come up again since it went in, but a couple of times when the wheel unlocks itself, instead of making the normal 'thump' unlocking noise, it makes a 'ratchet' type noise which doesnt sound right.
Does anyone else notice this ?
      08-25-2008, 05:48 AM   #22
mgarvey
mgarvey's Avatar
United Kingdom
30
The ratchet sound is what I got on mine, sometimes with the amber light and sometimes not. The E91 has been sold on now so it is BMW's problem - lets just hope the E93 doesn't develop the same fault.
Current: Skoda Octavia Scout 4x4 DSG
Previous: F30 318d Sport, R56 MINI Dooper 2010, E93 325i M-Sport auto 2007, E91 320d SE 2005, E46 318Ci Coupe 2002
