02-07-2019, 09:51 AM | #2 |
24
Rep 81
Never mind. I reached out to Brian Keller at Sun Motors and this was his response:
18 m2- # 36106881890 -- 79.00 EA 15m4 , old # was 36106856209- changes to # 36106881890 So if you are swapping all 4 it should not be a problem Thanks , I hope that helps. Brian So the M4 and M2 use the same TPMS. |
02-12-2019, 09:17 AM | #4 |
10663
Rep 6,938
Drives: 2018 M2 AW DCT
02-14-2019, 12:25 AM | #5 |
Life is on the Track, the rest is just waiting.
381
Rep 731
02-14-2019, 07:36 AM | #6 |
10663
Rep 6,938
I agree that the readings can be off by a few pounds. But it can tell you when you have a low tire. I find the TPMS gives me readings within one pound on all my tires. But it is still two pounds lower than my tire gage.
02-14-2019, 08:13 AM | #7 |
24
Rep 81
How do you know your tire gauge is correct? I guess you could ask how do we know the TPMS sensor is correct?
The answer is simply we do not know. BUT it does help to know the difference between each tire (assuming you are taking a measurement when cold as oppose after a spirited run). So if one tire is a few pounds off then you know you have an issue. BTW .. I believe you can turn off the TPMS warning light via bimmercode |
02-14-2019, 08:36 AM | #8 | |
10663
Rep 6,938
atc556.50 |
02-14-2019, 03:00 PM | #9 | |
300
Rep 357
FYI. I had a Jeep Grand Cherokee a number of years back. The TPMS was dead accurate although it only showed PSI, no temp. |
DanG10663.00 |
07-26-2020, 08:13 PM | #10 | ||
724
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
07-28-2020, 01:16 PM | #11 |
46
Rep 77
Does anyone know if tpms from a 2012 335i would work with the m2? I just got new wheels (titan7 ts5) and was hoping to use the sensors from my friends 335i
