TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Weird Nav problem
      06-25-2005, 01:10 AM   #1
agarbati
agarbati's Avatar
39
Drives: E90, Saph Blk 330i
Question Weird Nav problem
If I display my 'current position' in the window next to the map in the navigation it incorrectly shows my heading. The blue arrow in the navigation map and the compass on the mirror will correctly show my heading as, say NE, but the position window will show NW. If nav and mirror show SW it will say SE. It determines North and South correctly but E and W directions are 90 degrees out of sync with the nav map and the mirror. It's weird to see the nav small blue arrow pointing correctly but the current position arrow, in the window next to it, flipped in the mirrored direction.
Any tips?
      06-25-2005, 06:19 AM   #2
RachelS
46
Drives: 2006 325i
Take out the NAV disc and start the car. Turn the car off and re-insert the nav disc. Turn your car on and do not drive for 5 minutes. It need to re-gain satelites.. I was told and it worked for me.
      08-19-2007, 07:20 PM   #3
an0maly
an0maly's Avatar
Drives: 2007 BMW 335i
Nav heading issues
Same issue happend with me today, the E and W are totally out of sync.. I'll give your trick a try.
Thanks.
      08-19-2007, 10:23 PM   #4
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
Any tips?
Yes, your car is fine. The mirror compass tells you which way you are heading, the little arrow on the position window is meant to be like a compass needle -- it always points NORTH.
Take a second look at it and it will make sense.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
      08-19-2007, 11:56 PM   #5
an0maly
an0maly's Avatar
OK I feel like a total idiot. Thats right, that needle does always point North. Hense it always shows an N next to it. Is there any option to change this to show one's current heading instead ?
      08-22-2007, 07:24 PM   #6
dttkf
Drives: 2007 335i
2007 335i  [0.00]
2006 H3  [0.00]
I'm not by my car, but I believe I saw an option when you select what perspective you want it to read. Try looking at the perspective view and see if it shows car position. Sorry, couldn't be more help, I'm out of town, but believe I saw this when I was playing with it a couple of weeks ago.
DTTKF
07' 335i Montego Blue, 06' H3 Black
Gone but not forgotten
95' 318ti Black, 01' 325i White, 01' 330i Black,
02' 330ci Blue
      08-23-2007, 01:05 PM   #7
SoYank
SoYank's Avatar
Drives: 2009 E90 335i MT
There are three settings for the map: 1) Map with North always at the top, 2) Direction of travel at the top, 3) perspective where the road appears like your looking out the windscreen.
Obviously you have iDrive. So, for the options above simply say 1) "Map Facing North", 2) "Map, Direction of Travel", 3) "Map, Perspective".
Hope you don't get lost.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7
European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor
Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269
      10-20-2007, 02:13 PM   #8
rambalu80
rambalu80's Avatar
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
I was driving back home last night and my actual position and the position on the navi were totally out of sync. I tried planning a couple of routes from where I was and it really help. I kept driving and decided to remove and reinsert the DVD hoping that would help but in vain. I planned a route home again even though I was only a couple of blocks from home and it showed up just fine. I checked on it this AM and so for it looks good. I found this thread while looking for information and I hope it was just the Navi trying to regain satellites.
Do you guys think I should still take it to the dealership to have it checked out or just hope everything is okay and move on?
      10-20-2007, 09:02 PM   #9
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
The latter, unless it happens again within the next month or two. If it couldn't see the satellites, it might do something like this. And many units may start searching for sats that aren't there if they get really confused, in which case it could take up to 30 minutes or so to be "sure" about the position again. You're bound to see errors like this at times -- very rare, but it can happen with any GPS unit.
      10-21-2007, 10:08 PM   #10
rambalu80
rambalu80's Avatar
Thanks BK. The navi has been working perfectly fine since the incident. Hopefully will continue to do so and I guess I'm not gonna worry about checking with the stealership.
      08-14-2011, 02:55 PM   #11
mikeywilz
Drives: 2006 x5 3.0 and 2006 330i
navigation problem
In reply to those who felt stupid that the needle always points north... you can select whether you want it to point the direction of travel so it will always point upwards..you can select the map north and the needle will move EWSN on your screen.
