01-31-2019, 07:21 PM | #1 |
Rep 45
Drives: F10 535i
ECUs Missing in TAL Processing
Hi guys, looking for some insight here.
Previously I installed BM3, which broke a lot of things and I was advised to update all my ECUs. I did that and it fixed all my issues so I assumed that I was on the latest version of the firmware. I was coding and wanted to enable some things such as Compass in my Kombi, but realized that my firmware was too old. Upon digging, I discovered that I needed cafd_00000069.caf.010xxxx for it to work, but was currently on cafd_00000069.caf.009xxx. This sounded strange as I thought I had updated my ECUs successfully. I can confirm that I've got the latest psdzdata, I've checked and the cafd_00000069.caf.010xxxx file exists in there So I brought up ESYS and it is telling me I am still on: Using this guide http://www.bmwesys.com/guides/E-Sys%...CU%20Guide.pdf, I went to update my ECUs, however it isn't showing me any ECUs Vehicle is a 2012.03 F10 535i, but I posted here since the f30 forums are generally more active. Thanks in advance! |
02-01-2019, 05:47 PM | #3 |
Rep 45
Drives: F10 535i
02-01-2019, 06:49 PM | #4 | |
5886
Rep 10,256
It's interesting that you are not the first forum member to mention that F3x community is more active than other communities. |
02-03-2019, 06:45 PM | #6 | |
Rep 45
Drives: F10 535i
I'm looking for the latest CAFD so that I can (potentially) enable a compass in my Kombi Thanks |
02-03-2019, 06:53 PM | #7 | |
2374
Rep 8,364
You can also write updated I-step to car after flashing with VCM tab. |
iRoik4.00 |
02-03-2019, 07:00 PM | #8 |
Rep 45
Drives: F10 535i
Thank you, I'll give it a shot when I have some free time. Is it safe to assume that whatever CAFD version is in my psdzdata should be updated to the ECU?
02-03-2019, 07:26 PM | #10 | |
Rep 45
Drives: F10 535i
Cheers. I'll try again over the next few days when I have a moment |
