BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    B&W speakers in rear doors no sound
      01-28-2019, 04:37 PM   #1
ntingle
25
Drives: i8
Anyone else have this? No sound at all comes out of the rear door speakers; when you turn the F/R fader all the way back all I can hear is the center rear speaker.
Without the fader you can't really tell from the front seats, it's only really obvious to people sitting in the back.
Sometimes I can get them back by hitting the "reset" option in the B&W menu. But they don't last for long. I'm guessing there must be a short somewhere and the amp is turning off the channel.
I'm going to take it in but just wondered if anyone else had this problem.
      01-28-2019, 05:09 PM   #2
emmfive
emmfive's Avatar
74
Drives: 2001 M5
What's your audio source? I believe others have experienced the same, I want to say when audio source was set to satellite radio but not 100% sure.
      01-28-2019, 06:02 PM   #3
ntingle
25
Drives: i8
All sources.
      01-28-2019, 06:32 PM   #4
Ever34
325
Drives: F90 M5
Not 100% sure about what I'm saying but I believe there was a thread concerning this issue. The back would only work when logic 7 was selected.
Again it's been a while since I've read that thread
      01-29-2019, 11:01 AM   #5
ntingle
25
Drives: i8
That was this thread I guess:
https://f90.bimmerpost.com/forums/sh....php?t=1552174
Looks like it was referring to a HK system and satellite specifically. There's no "Logic 7" on the B&W.
      01-29-2019, 01:49 PM   #6
btsmith
47
Drives: 2019 BMW M5 Competition
I never really paid that close attention to it, but after reading this tread I tested mine out.
I have B&W and can confirm that no sound comes out of the rear doors. Only mid range sound from the back deck.
If Logic 7 is a HK proprietary thing what is causing this with B&W?
      01-29-2019, 02:17 PM   #7
ntingle
25
Drives: i8
Maybe it depends if anyone is actually sitting back there?? That would be crazy, wouldn't it? I'm not near my car to try this out at the moment though.
Also try hitting the 'Reset' option, that worked a couple times for me to get sound back there, though it didn't stay for long. Otherwise I would doubt they were actually wired up.
      01-30-2019, 02:01 PM   #8
RobRed
ID10T Specialist
90
Drives: F90 | F97
The Rear Doors are part of the "front" side of the fader. Because of the surround functions of the system the back passengers are treated the same as front.
If you fade to the rear you are fading to the rear deck not doors.
This may be of interest as a side topic: https://www.whathifi.com/features/bo...-series-review
      01-30-2019, 06:08 PM   #9
1claire
1claire's Avatar
Drives: BMW M5 Alpine White
It may be a hint at cracked or broken wires in the door to body loom, inside the boot. Pull back the rubber door boot and try to inspect?
      01-30-2019, 10:31 PM   #10
ntingle
25
Drives: i8
I experimented and it turns out it's simply that in Studio (the default mode) no sound goes to those rear door speakers, ever. If you change to, say, Lounge then it does.
The fader all the way to the rear also cuts them out, in any mode.
      01-31-2019, 02:58 AM   #11
RobRed
ID10T Specialist
90
Drives: F90 | F97
If the fader is centered I get sound out of all speakers - all modes. Are you getting tricked by the psychoacoustics of the DSP in Studio mode? Each mode has very different channel dispersion.
