01-26-2019, 06:06 PM | #1 |
202
Rep 533
Bimmercode Cheat Sheet
Is there a cheat sheet for bimmercode on how to code certain things? I can't find the turn off seat belt chime. Also expert mode doesn't really tell you how to navigate. It seems to be in code.
435i GC
01-26-2019, 07:21 PM | #2 |
1890
Rep 3,877
You might think there is a reason for it being called "Expert" mode....
Suggest not playing with it unless you are certain about your actions The normal mode is pretty much self-explanatory.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
01-26-2019, 07:26 PM | #3 | |
Rep 4
Also, Expert Mode is not for novice users, you can seriously mess-up (brick) your car if you don't know what you are coding. |
01-27-2019, 04:35 PM | #4 |
202
Rep 533
Hence the request for a "cheat Sheet" or guide if you will.
435i GC
01-27-2019, 10:19 PM | #5 |
175
Rep 614
Drives: 2016 F36 M Sport
I would imagine that the old cheat sheets for ESys should apply to BimmerCode expert mode, no?
E.g., wouldn't "FEM > 3061 LceLciOutputChannels > FRA_V_L_IS_LED > aktiv" be the same instructions for ESys and BimmerCode expert mode? Idk, I haven't actually used BimmerCode yet, just viewed the demo mode
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
01-28-2019, 02:24 AM | #6 |
94
Rep 172
Drives: 2015 328i
It applies, use the module number for reference.
