2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning rear differential leak (Xdrive)
      01-25-2019, 09:00 AM   #1
M235
28
Drives: BMW M2
2016 M235i X-drive with a milage of 50,000km or 31,000 miles.
noticed an oil leak all over my rear differential, clearly both seals on each side are leaking . its not leaking to the point where its dripping on the floor but very noticeable all over the differential it self.
could it just be bad seals from the factory which i can deal with or is the differential on its way out ?
couldn't find any previous posts on this since its not a common problem... wondering if this happened to anyone before.
M2 - Fully Built engine Carrillo H-Beam Forged Rods, cp Forged Pistons- BigBoost Turbo Stage 3 - Fuel It LPFP Stage 3 (dual walbro 450) connected to 950cc port injectors controlled by aic6 - Dual s55HPFP - SSP-R Clutch - CSF Radiator, Oil & DCT Coolers - EOS Intake Manifold - MSR front mountintake system
      01-28-2019, 12:37 PM   #2
cybergym66
MHD Stage 2+
cybergym66's Avatar
Drives: 2015 M235 xDrive
Rear Axle Leak
Just had my engine oil changed...mechanic at BMW says the rear axle leak is a common issue...BMW quoted me $1400 for repair! I think I'll just refill the axle and see how quickly the gear oil leaks out!
      01-28-2019, 02:21 PM   #3
overcoil
3076
Drives: M235i 6spd
My Mercedes (2002 C-class) axle weeped from the seals. I think the tech said it wasn't a mandatory or urgent repair.
      01-28-2019, 02:32 PM   #4
M235
28
Drives: BMW M2
Guys, im talking about the rear differential (N55)...... not Axels....
      01-28-2019, 03:43 PM   #5
overcoil
3076
Drives: M235i 6spd
yeah rear diff weeped in my Mercedes. you could wipe your finger on the bottom along center and get a finger tip full of grease - but mine hadn't gotten to the point of dripping.
      01-28-2019, 03:53 PM   #6
M235
28
Drives: BMW M2
Yes same here scott.. not to the point of dripping. Now i get the fix is simple.. just a change out the seals, but i dont know how long its been there (most probably months) also ive been tracking the car... so im trying to figure out if my differential or transmission took a hard beating or not
      01-29-2019, 07:01 AM   #7
cybergym66
MHD Stage 2+
cybergym66's Avatar
OK, just to clarify...It's my rear DIFFERENTIAL that is leaking, not my rear axle...still...BMW wants $1400 to replace seals.
      01-31-2019, 01:32 AM   #8
mibikin
Drives: Alpine White M235i xDrive
I got it replaced under warranty but my car was making a weird howling noise and they ended up changing my differential because it was apparently completely empty of fluid or had metal shavings inside, I was told two different things but got the differential replaced under warranty. Never noticed a leak or anything but that's what they told me. Can't really comment on price cause it was a warranty repaid but I can say I'm someone else who probably had the same issue.
      01-31-2019, 08:12 AM   #9
M235
28
Drives: BMW M2
1400!!!!!!!!!!!!!! seals cost $10 each... how did you get charged 1400? that cant be for just diff seals
      01-31-2019, 08:16 AM   #10
M235
28
Drives: BMW M2
yeah im covered under warranty. can you explain the howling noise? and when you do hear it? (slow or high speeds)
im asking because i sometimes hear a howling sound as soon as i first drive off after the car has parked for a while, but then it goes away after a minute or so.
      01-31-2019, 12:22 PM   #11
cybergym66
MHD Stage 2+
cybergym66's Avatar
ESTIMATE!!! I didn't get it done...seems WAY too high (Quoted 6hrs to do work). I need to go to a Indy BMW shop who has the BMW specific tool to accomplish the work...tried my usual shop and they said they didn't have the right tool to do the work. Cost $10 to top off the Diff gear oil...I'll see how quickly I lose the gear oil.
M23528.00
      01-31-2019, 03:11 PM   #12
mibikin
My car was howling most noticeably between 30 and 50 mph. Above that it wasn't really noticeable
M23528.00
      02-01-2019, 05:36 AM   #13
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Had both that and the transfer case go on GFs previous F30, they covered it under warranty / goodwill but it was not a cheap repair. Would have been close to $5K for both.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
M23528.00
2addicts
