2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Air flow max when defogging
      01-17-2019, 10:12 PM   #1
2 Lover
18
Drives: 2017 F22 230i xDrive
As you know, when press the defog button, air flow is set as maximum.
Is there any way to change this by coding (bimmercode)?
It is just annoying whenever I press defog button..
      01-18-2019, 09:47 AM   #2
DaleHeinz
DaleHeinz's Avatar
221
Drives: M240Xi Estoril Blue
Mine comes on one level down from max. I thought it was able to remember the last setting used, but I'm not sure.
      02-12-2019, 02:32 PM   #3
wyu177
9
Drives: 2019 m240i
Yes I have noticed it goes to max, and even if you adjust the fans to a lower level, the heat comes out max level too. I have been reading another way of defrosting is not using that defrost button but instead setting the air button to distribute air to the top vents only + not recirculate and then turning on AC if necessary. I haven't had my windows fog up since reading this so i haven't seen if this works or not.
2addicts
