M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Volk TE37 18x10 +25 Square setup fitment question
      01-14-2019, 10:35 AM   #1
atc5
Drives: 2019 M2C, Bolt, 98 Type R
Hello All,
(Yes i searched and no it's not easy to search for wheel sizes given the way people type them out and the content is indexed )
Does anyone know if this will work, or perhaps even run this wheel size as a SQUARE setup?
I've got a set of TE37SL's accessible to me for track use and would like to know if this (mostly the offset) is an acceptable option.
Thanks!
      01-14-2019, 10:47 AM   #2
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
Those are going to stick out well past the fenders.
Assuming you go with 275x35r18 tires, you're looking at the following differences from stock
FRONT:
- Suspension clearance: 11 mm (0.4'') closer to suspension/brakes components.
- Fender Clearance: Will stick out 19 mm (0.7'') farther.
REAR:
- Suspension clearance: 100% clear (leaves even more room than OEM)
- Fender Clearance: Will stick out 20 mm (0.8'') farther.
Source: http://www.rimsntires.com/specspro.jsp
atc556.50
      01-14-2019, 10:51 AM   #3
atc5
Thank you very much for the details and link!
      01-14-2019, 11:20 AM   #4
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
It will fit just fine at stock height with a little camber. I ran 18x10 EC7 +25 with 275 and 285 tires.
https://f87.bimmerpost.com/forums/sh....php?t=1370889
atc556.50
      01-14-2019, 11:31 AM   #5
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
Nice.
Yeah, if looks like if you're lowered at all, you're going to run into some issues with that aggressive offset.
      01-14-2019, 11:33 AM   #6
CosmosMpower
2051
Nice.
275's, would be close. 285's yes would definitely hit the fender. Keep in mind those are also wider race tires, not street tires.
I had -2.5 camber in the front.
atc556.50
m2
