01-14-2019, 08:41 AM | #1 |
3618
Rep 4,532
Look what arrived to Flow Bench Test tonight
Thanks to Miko, I’ll have a stock airbox and a stock filter to test. Plus a front cat. BMC just arrived ! Mega test tonight !
01-14-2019, 12:12 PM | #3 |
194
Rep 459
Keep us posted my BMC filters are arriving soon
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package 2013 Lamborghini Aventador-Pearl Green-Modified 2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
01-14-2019, 10:05 PM | #7 |
3618
Rep 4,532
Longggg night on the bench....had some Porsche stuff too
For reference, a straight 2.50" pipe flows 514cfm at 28" on my bench. 2017 650hp ZO6 main cat flowed 485CFM. 1. BMW M5 Main Cat flowed 524 cfm at 28". Best Main Cat Stock I've had on the Bench. Secondary Cat was 542 cfm at 28". 2. Airbox flow was tested at 10" since my car maxed out at 10" at 21.5psi of RaceChip boost at 7000rpm when I tapped the Intake with a digital manometer. Wanted to keep it real world. 3. Stock Airbox, stock filter, no charcoal filter, flowed 445cfm at 10" 4. Stock Airbox, BMC filter, flowed 492cfm at 10" 5. Open hole cut to fit the airbag inlet, flowed 511cfm at 10" which is perfection. Basically like removing the total airbox assembly and running just the pipe to the turbo. MEGA THANKS TO MIKO....no test results without him. GREAT GUY !!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
01-14-2019, 10:56 PM | #8 |
12916
Rep 18,686
Great testing onfireX5
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
01-15-2019, 10:33 AM | #10 |
955
Rep 765
soooma1376.50 Catchmeifyoucanf9054.00 |
01-15-2019, 10:57 AM | #11 | |
3618
Rep 4,532
1. Remove the factory charcoal filters and air filters. Replace with BMC filters and you have removed all airbflow restrictions. You will not get the sound or looks of aftermarket, but the same airflow as the tubing necks down even smaller to the turbo. 2. The OEM BMW F90 cats are the BEST I’ve had on my bench. Even outflows the HJS 100cell Motorsport cats with a 3x2.50 inlet outlet. Flows better than a 2.50” straight pipe, but less than bypass 3” pipes. 3” pipe 790cfm > F90cat 524cfm > 2.50”pipe 514cfm. |
01-15-2019, 11:54 AM | #13 | ||
955
Rep 765
soooma1376.50 |
01-15-2019, 12:01 PM | #14 |
194
Rep 459
Nice test and results! BMC's are on the way from Europe!
01-15-2019, 12:17 PM | #16 |
194
Rep 459
yes
01-15-2019, 12:31 PM | #17 |
///M
6652
Rep 3,683
Stay away from oiled filters for F10 and F90 M5
Life is too short...enjoy your life
///M |
01-15-2019, 12:34 PM | #18 |
325
Rep 519
Thanks That's why I was asking...have no interest in using oiled filters.
01-15-2019, 06:57 PM | #20 | ||
191
Rep 292
01-15-2019, 07:15 PM | #21 | |
///M
6652
Rep 3,683
Did you measure the cats I.D.? Is it 2.5"? Very impressed with primary and secondary cars! Didn't expect that stock air filter is only off from straight pipe 15% And 10.5% from BMC filter.
///M |
soooma1376.50 |
01-15-2019, 07:19 PM | #22 |
194
Rep 459
There is no MAF on the F90 M5......and no issues with oiled filters and MAF ...as long as you clean the MAF with MAF cleaner on a regular basis
