2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions LCI Adaptive LED Coding-off Sidemarkers
      01-08-2019, 01:26 PM   #1
samsamdar
samsamdar's Avatar
585
Drives: OG M2
2018 BMW M2  [6.67]
Anyone know the coding to turn off the sidemarkers on the Adaptive LCI LED headlights? Bimmercode isn't working (it thinks that I have normal bulbs installed in their position; even though I have LEDs). Thanks!
      01-22-2019, 12:03 PM   #2
samsamdar
samsamdar's Avatar
585
Drives: OG M2
2018 BMW M2  [6.67]
Bump - anybody know how to do this?
      01-22-2019, 04:20 PM   #3
Climate Changer
Climate Changer's Avatar
Drives: 2018 230i xdrive convertible
2018 230i xdrive co ...  [0.00]
2019 x3  [0.00]
In Bimmercode-
Front Electronic Module- Lighting- Sidemarkers-Not Active
Also to choose your bulb type and warm/cold monitoring
Front Electronic Module- Voltage Monitoring- Sidemarkers
Hope this helps
      01-22-2019, 11:29 PM   #4
samsamdar
samsamdar's Avatar
585
Drives: OG M2
2018 BMW M2  [6.67]
Originally Posted by Climate Changer View Post
In Bimmercode-
Hope this helps
Will this work for the adaptive LEDs?
      01-23-2019, 07:48 AM   #5
Climate Changer
2019 x3  [0.00]
I'm no expert but the adaptive LEDs are headlights and have nothing to do with the sidemarkers.
      01-23-2019, 02:03 PM   #6
samsamdar
samsamdar's Avatar
585
Drives: OG M2
2018 BMW M2  [6.67]
Did that coding work for you? Do you have the LCI adaptive lights?
OG M2 with the OEM M mirror retrofit
      01-23-2019, 04:16 PM   #7
Climate Changer
2019 x3  [0.00]
[QUOTE=samsamdar;24280593]Did that coding work for you? Do you have the LCI adaptive lights?
The coding worked for me. The are always off except when using the turn signal. My car is 2018 230i standard LED lights not the adaptive.
      01-23-2019, 04:50 PM   #8
samsamdar
samsamdar's Avatar
585
Drives: OG M2
2018 BMW M2  [6.67]
[QUOTE=Climate Changer;24281263]
I will try the coding tonight - are your side markers separate from your turn signals?
      01-23-2019, 05:25 PM   #9
Climate Changer
2019 x3  [0.00]
I'm getting confused. you mentioned headlights and I thought you were referring to the parking lights to stay off. Which is the turn signal as well.
      01-23-2019, 07:53 PM   #10
samsamdar
samsamdar's Avatar
585
Drives: OG M2
2018 BMW M2  [6.67]
This is the sidemarker for the LCI Adaptive lights - I think your sidemarkers are the same lights as your blinkers.
      01-24-2019, 08:10 AM   #11
Climate Changer
2019 x3  [0.00]
Gotcha. I Thought you were referring to the parking light.
Sorry I did not code that off. You should code the parking lights off.
It makes the front look cleaner, no amber.
I do have the sidemarker lights as well just BMW LED not adaptive.
I didn't know that light strip was the sidemarker
      05-23-2019, 05:43 PM   #12
Lex G
Drives: BMW ActiveHybrid 3
Hello everyone, I recently turned my side markers off and was wondering why my angel lights turn off once I switch the lighting. Anyone know how to enable them back? Thank you it's for a 2013 Activehybrid 3
Lex G
      08-15-2023, 03:54 AM   #13
samsamdar
samsamdar's Avatar
585
Drives: OG M2
2018 BMW M2  [6.67]
Just updating this old thread cuz I finally figured out how to do it in protool lol
In both FLE modules (right and left) change the following:
LM_ID_LT04: change from value 02 to value 01
LM04_Name: change from value 02 to value 01
Front sidemarkers are now turned off for the adaptive LED headlights!
2addicts
