View Poll Results: Should I get rear windows tinted? | |||
Yes - for sure you should go tint boy!! | 18 | 81.82% | |
No - tinting is the devil's work, avoid. | 4 | 18.18% | |
Voters: 22. You may not vote on this poll |
01-07-2019, 09:44 AM | #1 |
Deadly
1315
Rep 2,077
Rear window tinting
This is my last moan on this. SO a spot poll.
I didn't realise my rear windows (passenger, quarterlight and trunk) would not be tinted. It must have been implicitly included in some option I had in past, or I'm just plain st2pid. I kinda liked it on my previous two vehicles, I feel a little naked now :-o Should I got for reputable 20% tint provider? Or leave as is ... Let the masses decide :-) |
01-07-2019, 10:40 AM | #2 |
The limit of adhesion is my home.
1702
Rep 3,778
Isn't it the opposite though??? It's the windshield, front driver & passenger side windows that are NOT tinted.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
01-07-2019, 10:41 AM | #3 |
214
Rep 485
Maybe in the UK, they come untinted in the back? Perhaps "privacy glass" is an option over there instead of being standard like in the States?
01-07-2019, 10:41 AM | #4 | |
327
Rep 967
G01 X3 30d 2018-09 - Sophistograu Brillanteffekt Metallic/ Leder Vernasca Mokka Dekorsteppung
D69GMB463.00 |
01-07-2019, 10:43 AM | #5 | |
327
Rep 967
Some countries get rails but no tint standard (Sweden), other no rails, etc. It's a salapa code as most things on the car.
01-07-2019, 10:47 AM | #6 |
383
Rep 1,054
They call it Sun protection glass in UK which is a little confusing, it's a stand alone option or comes with M Sport plus pack
Only thing to be weary of with aftermarket tint, is it can make the wires stand out for heated rear window and side aerial and you can also end up with a thin visible line around the existing black edging on the glass, make sure you see one first |
01-07-2019, 10:57 AM | #7 | |
Deadly
1315
Rep 2,077
And yup - I am doing research into reputable shops, preferably recommended b y a main dealer to avoid both the wires and those dimply black things around the edge of window being any issue. It's amazing in such a world of pain and anguish how such an almost infinitely trivial thing can wind one up :-) |
01-07-2019, 11:10 AM | #8 |
317
Rep 343
Drives: '19 750i xDrive
01-07-2019, 12:19 PM | #9 |
Deadly
1315
Rep 2,077
01-07-2019, 12:20 PM | #10 | |
327
Rep 967
But I also think BMW admitted a bad batch of ambient light strips, no? Apparently it's quite complicated, and perhaps bad design in combination with the stress of wet tinting ...
01-07-2019, 03:46 PM | #11 |
197
Rep 832
Drives: 2019 G01 X3
Not sure if it matters, but I only tinted the front two windows, and yet the ambient lights went completely dead on the front driver's door and both rear doors. Front passenger door still works except for the top strip. Taking it to dealership next week.
01-07-2019, 03:53 PM | #12 | |
Deadly
1315
Rep 2,077
What did they do? Just the film on the window on the inside - i.e. they didn't remove the door panel to install right? I don't believe that's the usual way. I'm puzzled how (if they didn't remove door panel) the film could affect the lighting loom (the film being what, 0.1mm thick?). Do tell! |
01-07-2019, 04:13 PM | #13 |
Deadly
1315
Rep 2,077
I wonder ... when I spoke with one provider they were quite adamant that one should not wind down windows for at least a couple of days to allow curing/healing/sticking whatever. The only thing I could see that could f**k up wiring to led strips is if you were not told this, used windows and then errrkrkrkr.
Having said that - it would have been plainly obvious when you wound the window back up and the tint was all fubar :-/ So I should've deleted the above based on logic, but hell I wrote it now!! |
01-07-2019, 04:22 PM | #14 | |
793
Rep 998
01-07-2019, 11:41 PM | #15 |
327
Rep 967
Perhaps there are control modules for the led strips, in the front doors, that can get affected by soapy water... modules that feed the rear as well.
01-08-2019, 01:38 AM | #16 |
327
Rep 967
From the Technical Training Guide:
"RGB (Red, Green, Blue) LED modules are used for the ambient lighting. The lighting for the ambient interior lighting is controlled via a separate LIN bus. The individual LED modules are connected via a local interconnect network bus. The LED modules are connected in series to the LIN bus around the vehicle. If the LIN bus is interrupted at a certain point or the micro controller on the LED is faulty, then further light transmittance is interrupted at this point. A search for the fault must be carried out at the location where the last LED illuminates." |
01-08-2019, 04:23 PM | #17 | |
197
Rep 832
Drives: 2019 G01 X3
99% sure they did not remove the door panels to tint. I've never heard of anyone doing that. We were told not to roll the windows down for at least 3 days, and we followed those instructions (actually kept them up for a week+). |
