01-02-2019, 02:13 PM | #1 |
230
Rep 631
Oh dear, I swore quite a lot.
Hi, new member here although I have posted a few with no introduction, sorry.
Today, whilst reversing into a tight space in a concrete carpark, I foolishly nay stupidly allowed the outer rim of my wing mirror drag along a supporting beam. Not that bad but A- extremely visible from my point of view and B - annoying. After trawling the whole internet from start to finish, I have identified the correct part number as: 51 16 7 284 124 - Would any of you kind folk know if it is just an unscrew ang jiggle job or should I let my friendly dealer do it, or should I man up, get some fine sand paper, twiddle it a little the get my detailer to smooth the offending scrape with a fine grit paste? Pictures to follow but it is dark and I cannot bear to look at it again. For the record, it's an Estoril Blue, F30 335D Xdrive LCi and completely pristine, apart from the mirror!! |
01-02-2019, 02:45 PM | #2 |
Old Fart
361
Rep 694
Sounds like it's time for black or carbon mirror covers. I'm sure you can justify it with a bit of man maths
The doctors said it's OK to listen to the voices..... just don't do what they tell me
01-02-2019, 03:08 PM | #3 |
230
Rep 631
Hi thank you for the suggestion, I’d be all for it if it wee the cover, it is the black surround bit, although, I did go to take a picture and decided to give the offending scuff a little buff it seems to have done the trick, it was dark though, I’ll rub in some black shoe polish and report back.
01-02-2019, 03:13 PM | #4 |
83
Rep 348
It's not hard but you can easily break the mirror, look for videos on youtube, I know Brain @ Kiesmotorsports did a great video on it. As long as you follow all instructions, you should be fine. If you've looked at the instructions/videos and still think it's too hard, just let the dealer or mechanic do it.
https://www.newtis.info/tisv2/a/en/f...les/1VnYCfz455 https://www.newtis.info/tisv2/a/en/f...soles/GxVcVmQ8 |
01-02-2019, 03:15 PM | #5 | |
83
Rep 348
01-02-2019, 03:27 PM | #6 |
309
Rep 649
Sounds like it's just the black bottom cap which is the most prominent point. Both sides of mine were scratched by passing traffic, builders vans, within a week of getting the car. They're only £25 each if you can't polish it out.
Note to self, must park closer to the kerb and fold the mirrors. Q
2018 440i Gran Coupe, MPPSK, Champagne Quartz, Ivory White, Adaptive Susp., Sunroof, Active Security, CA and a few other bits.
01-02-2019, 04:20 PM | #7 | |
230
Rep 631
01-02-2019, 04:22 PM | #8 | |
230
Rep 631
01-03-2019, 01:56 PM | #9 |
230
Rep 631
So!
After speaking to the parts department at my local dealer I now know, the part is £35 ish, it is readily available, best not to try to change it myself. The Bodyshop claim it will take 11/2 hours so, all in about £100.00. My bodge job looks almost perfect, I will go see my friendly detailer on Saturday and then decide. Thanks all for your suggestions.
01-03-2019, 02:05 PM | #10 |
288
Rep 637
Are you sure that's the right part? M Sport cars (as yours is EB, I assume it's an M Sport) have gloss black and the part number you've given is for the grainy black?
The gloss ones are: Left: 51167284125 Right: 51167284126 http://www.realoem.com/bmw/enUS/show...diagId=51_9005 They're reasonably easy to swap over after popping the glass off, undoing some screws for the lens adjuster and popping some clips - I had to replace the drivers' side one on my F30 AUC when I bought it as the first time I waxed the car, I noticed a crack which I then couldn't not see.
F90 San Marino Blue/Black
01-04-2019, 11:56 AM | #11 | |
230
Rep 631
01-05-2019, 02:13 AM | #12 |
288
Rep 637
Bearing in mind I did this almost 5 years ago now, this is from memory.
I think the scariest part was popping the glass off as you seem to need a large amount of pressure until it lets go - I used a 1" wide flat chisel wrapped in electrical tape (to protect any edges from sharp bits) to spread the load. Beyond that, it was just a case of unscrewing and unclipping the adjustment motor and identifying the clips joining the parts together and carefully prising them open to separate the parts, then jiggling bits to get them separated. I recently had to replace the lower part of a mirror housing on Mrs T's Fiesta when she tried rearranging it into many smaller parts and it was pretty much the same component parts as the BMW mirrors with an internal frame, base, surrouding ring, indicator unit, cover, motor and mirror glass.
