01-01-2019, 09:55 AM | #1 |
423
Rep 644
ACS Dampers - Should I or shouldn't I?
I'm considering getting the ACS dampers fitted to my car which is a 430d F36 X-Drive. I've already had the ACS springs fitted and that has improved the look/stance of the car and improved handling. I'm able to take advantage of the free fitting offer through Lorcan on the dampers because I've already got the ACS springs.
If I'm honest, I do find the ride of the F36 a bit fidgety, especially at lower speeds on urban roads but it's also easily unsettled at higher speeds too and can feel almost crashy. I'm planning on keeping this car for a long time as it's got a great spec so I'm thinking whether the dampers would improve it further. I don't really thrash my car about and aren't one for getting the back end out at every opportunity so would it be pointless to get the dampers fitted? They'll cost about £1200 which I think is pretty reasonable to be fair, it's just whether I'll see any real benefit from fitting them, I'd appreciate your opinions. Cheers |
01-01-2019, 10:20 AM | #3 |
423
Rep 644
01-01-2019, 10:44 AM | #5 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
I'm a long way from being an expert, but what I do know is that to get the best out of a suspension the springs and dampers need to be considered as a matched pair. I upgraded my springs fairly early in the life of my (passive) 335i f31 and in general I've been pretty happy but I do still think the ride on the car is jittery and at times I can feel lack of traction over uneven surfaces that should not be phasing the car as it does. So, I reckon adding the dampers will probably be worthwhile.
I'd have liked to have taken a drive in the demo car, but work kept me busy so I'm going to have to take a punt. My car's now four years old and 50k miles so I guess it's someway into the lifetime of the existing dampers anyhow so it's not a completely crazy thing to take a gamble on. Finally - I was a rear-seat passenger in a colleague's F36 recently and I found the ride absolutely appalling. That was a bog-standard setup with RFTs, but by the time I got out from a Heathrow to Midlands trip I was feeling pretty ragged! |
Hugrov423.00 |
01-01-2019, 10:59 AM | #6 | |
423
Rep 644
Lorcan did mention in his post regarding the ACS dampers that the F36 seems to be particularly affected when it comes to ride quality, it's a cracking car overall but the ride quality could definitely be improved. |
01-01-2019, 12:57 PM | #7 |
8571
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Yes you should. The dampers will make more difference than the springs did. I say this because you said you will be keeping the car for quite a long time, in which case it's a no brainer for me. I don't know anyone who fitted better dampers to their car and regretted it!
At the weekend I took my dad out in my M4, which now has ACS RS coilovers fitted and after 10 mins he said it was amazing compared to before and he was ordering new dampers for his car! His M135i is standard just now, so he's mulling over the Birds option, or the ACS sports springs and dampers, but one way or another he's fitting a matched spring and damper set up.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
ryanwarriors9199.00 Wills28657.50 |
01-01-2019, 01:05 PM | #8 |
116
Rep 793
I am in the same boat and agree with everything that Hugrov has to say.
only difference with mine is that its has adaptive - so reluctant to lose an option which cost £600 (i bought my car second hand) my understanding is the ACS dampers are just B8 (revalved). Blistein do a B12 kit with eibach pro springs (B8 dampers) Works out cheaper? |
ryanwarriors9199.00 |
01-01-2019, 01:07 PM | #9 | |
423
Rep 644
Yes, I'm definitely thinking this car is gonna be long term, the GC is a great car for me personally and the spec on mine is fantastic so it makes no sense for me to think about another car for a number of years (most unlike me). I do feel it's let down by the way it handles the lumps and bumps on our roads so if I could improve that it would be an absolute bonus, sounds like the ACS dampers would do exactly that from the reviews I've read so far. |
01-01-2019, 01:10 PM | #10 | |
8571
Rep 19,982
When I drive our 330e (company car, so no mods) and feel its combination of run flat brittleness, with standard damper crashiness, and weak body control it feels very weird indeed.
01-01-2019, 01:15 PM | #13 | |
8571
Rep 19,982
And besides, it just gives you 2 versions of rubbish, when you can have one right setting instead! I'm not sure which hardware is used by ACS for the dampers, I know they use KW for the coilovers as base hardware. The B12 kit might be better for you if you're completely standard, but if someone already has the ACS springs then the current offer of free fitting would make that a better option. Bilstein do a B6 or B8 damptronic for some cars, might be worth checking if that's available for yours, then you can keep adaptive suspension. I have the B8 sprint damptronic on my Boxster as it had the PASM adaptive suspension option. It works very well.
01-01-2019, 01:17 PM | #14 | |
116
Rep 793
is adaptive still the way forward though as the top end M4 Competition and CS has adaptive |
01-01-2019, 01:21 PM | #15 | |
116
Rep 793
agreed lot of money. |
teaston10995.50 |
01-01-2019, 01:24 PM | #16 | ||
423
Rep 644
01-01-2019, 01:29 PM | #17 | |
8571
Rep 19,982
I really don't miss the adaptive option as used to use sport mode 90% of the time anyway. Comfort mode was too lacking in control for my liking.
01-01-2019, 01:33 PM | #18 | |
199
Rep 585
I will be coding out the adaptive too at the same time if my new car has it that is |
01-01-2019, 01:40 PM | #21 |
199
Rep 585
again all depends on budget you can get a b12 kit for around £600 keep an eye out on auto doc or ebay german companies, I have researched and looked into coding out too
Module is in the boot needs to be un plugged and then coded out will save you a fortune over electronic dampers |
01-01-2019, 01:46 PM | #22 | |
116
Rep 793
That's a bargain!! |
