12-29-2018, 07:45 PM | #1 |
102
Rep 240
M-Sport Suspension/Performance Difference?
Hi - I am looking at placing an order soon. probably before year-end.
I've read the forum and spoken to the dealer and there's not a clear answer that I can find: what is the difference in the suspension/performance on the M-Sport Package vs. base X5? - the M-sport includes the Adaptive M Suspension -what exactly is the difference vs. base? Both vehicles have an 'adaptive' mode. - if you opt for the air suspension (in order to get Adaptive Steering), does this negate any benefit of the above? thanks for any assistance.. |
12-30-2018, 01:38 AM | #2 | |
146
Rep 533
tastes jigga317.00 |
12-30-2018, 10:55 AM | #3 | ||
102
Rep 240
Thanks for pointing me to that post, I had not seen it. Many posts on this forum have been very helpful in educating me about pricing, options, etc. and I appreciate all of the members here.
In summary: (1) There's the standard X-Line suspension (2) M-Sport has: Quote:
I drove the X-Line and the M-Sport yesterday and I didn't notice much difference. I was able to test on roads with good elevation changes and tight curves. I need to test the M-Sport vs. the ZHC as I'm having a difficult time understanding how ZHC provides both "more comfortable" and "more agile" characteristics. Further, from that post and a couple others, it seems that some people are saying that ZMP + ZHC is the closest we can get to ZDH on a 40i? So, my test will attempt to see if ZHC helps with roll on corners, which is the only thing I didn't like. |
12-30-2018, 11:26 AM | #4 | |
4365
Rep 4,246
Adaptive M Suspension 2VF offers modified suspension and damping characteristics compared to the basic chassis and suspension via the Driving Experience Control. Influence of the Driving Experience Control on the EDC control: • COMFORT • SPORT The SPORT driving mode offers a much sportier damping characteristic at the expense of driving comfort. As noted, ZHC replaces 2VF on M Sport with 2-axle air and integral active steering. 2-axle air is "more comfort" and ease of loading where "more agile" handled by IAS. IAS is operated electromechanically by turning the rear wheels in either the same direction as the front wheels or the opposite direction – depending on the vehicle speed – optimizing cornering agility. IAS also assists in maneuvering into and out of tight parking spots. Neither will provide electric active roll stabilization front (EARSV) and the electric active roll stabilization rear (EARSH) in the DHC (50i only). Most members have noted better roll control than prior generation (F15).
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
12-30-2018, 11:39 AM | #6 | |
102
Rep 240
In your final comment regarding roll control, I think you meant for all suspensions vs the F15, not only ZHC - is that correct? |
12-30-2018, 11:56 AM | #7 | |
4365
Rep 4,246
Compared to my xLine F15, there's better roll control in the G05 but not where I would consider flat. I'm leaning towards M Sport with ZHC not for comfort but for ease of getting in/out, cargo loading and better turning radius - parking in the city is a pain.
12-30-2018, 11:57 AM | #8 |
4365
Rep 4,246
Mmm hmm, adaptive is the way to go for long trips.
12-30-2018, 11:58 AM | #9 | |
4365
Rep 4,246
02_G05 Powertrain-Chassis.pdf
12-30-2018, 01:43 PM | #10 |
691
Rep 978
From what I've read (I may be wrong here), unless you change from the M-Sport Suspension's default dampening - using the Driving Experience Control - the Standard X-Line and default setting M-Sport suspension should feel identical. The difference with the M-Sport is the ability to change the dampening. Did you try changing dampening via Driving Experience settings on the M-Sport test drive?
12-30-2018, 02:27 PM | #11 | |
37
Rep 139
12-30-2018, 03:12 PM | #12 |
Rep 27
I'm also consider a G05 40 M-sport with ZHC vs standard M sport suspension. I am currently driving a Macan with Air Susp and PASM (adaptive dampeners with sport setting) and want to get something similar in the G05.
So My understanding based on the tech document and posts on this forum is that: 1) Base suspension (X-line) has steel springs and electronic dampers that adapt to conditions but are not adjustable to a firmer/sportier setting 2) M-Sport standard has the same steel springs and electronic dampers but they dampers are adjustable via a console on the button for a firmer/sportier ride as desired 3) M-Sport with ZHC has air springs as well as electronic dampers that are also adjustable for a firmer/sportier ride. The air springs can also be lowered 0.8 inches for a lower center of gravity and an even sportier ride, and can be optioned with 4-wheel steering for better high and low speed agility. Of course the 50 can also get DHP with active anti roll bars, but this isn't available on the 40. So my conclusion is that on the 40, M-Sport with ZHC/air is the preferable option and should handle better than the standard M-sport because of the 4 wheel steering and ability to lower 0.8 inches. Although some might prefer the steel springs on the M-sport as sometimes air susp can feel "floaty" or "disconnected". Does this sound accurate? |
Auricom4364.50 |
12-30-2018, 04:14 PM | #13 | |
4365
Rep 4,246
I prefer a more sportier suspension and the standard M Sport adaptive M suspension more than adequately suits my everyday driving needs - sporty ride when needed and comfortable for long hauls. Though would ZHC solve issues that I have with my F15 - wide turning radius, high load height and entry (for us short people xD). Just want to inform individuals optioning ZHC should have the mindset that it isn't the handling cure-all for the lack of ZDH option for 40i. As the training guide notes: "The main purpose of the air suspension is to increase driving comfort. The system performs adjustment mainly at standstill, e.g. in order to compensate for a change in height due to the vehicle load. The inertia of the system means that it cannot react to driving dynamics disturbance variables, which may occur when the vehicle is driven quickly on twisting roads."
12-30-2018, 05:51 PM | #14 | |
691
Rep 978
The difference between the base X-Line suspension and the M-Sport suspension is the ability to change the damping. <snip> Adaptive M Suspension 2VF offers modified suspension and damping characteristics compared to the basic chassis and suspension via the Driving Experience Control. Influence of the Driving Experience Control on the EDC control: • COMFORT • SPORT |
12-30-2018, 05:53 PM | #15 | |
85
Rep 218
I would have preferred to have IAS only with M Sport Adaptive M suspension but unfortunately IAS is not feasible without Air Suspension (from any manufacturer that I am aware of). Keeping my fingers crossed as no one has described experience of Air Suspension equipped M Sport 40i, or compared rides of M Sport 40i with and without Air Suspension. Hoping someone will, soon! |
12-30-2018, 07:26 PM | #16 | ||
281
Rep 494
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold) 2012 BMW X3 28i (sold) |
12-30-2018, 07:31 PM | #17 | |
281
Rep 494
12-30-2018, 07:39 PM | #18 | |
85
Rep 218
I would have loved to order IAS alone on MSport 40i. |
12-30-2018, 07:53 PM | #19 | |
4365
Rep 4,246
They're all using steel spring struts xD ZDH is also modified suspension and damping characteristics with electric active roll stabilization, rear axle differential lock and IAS thrown in. 2VH air is only different as it uses air suspension struts. It's only different when you add in 2VH and IAS.
12-30-2018, 07:56 PM | #20 | |
4365
Rep 4,246
12-30-2018, 08:09 PM | #21 | |
281
Rep 494
ZHC is not available in Canada. We have standard springs and then if you upgrade the suspension set up, you can choose air or M adaptive with our without the M sport package and IAS. |
12-30-2018, 08:40 PM | #22 | |
691
Rep 978
I'll add - I believe "Driving Experience Control" is discussed in the owner's manual as "Driving Dynamic Control". |
