BMW 5-Series (G30) Forum 2017+ BMW 5 Series (G30) General Discussions Comfort lighting not working
      12-28-2018, 08:12 PM   #1
Mach550
Mach550's Avatar
Drives: 2019 M550i
2019 BMW M550i  [8.00]
I set the headlights or whatever lights are used for this function on 60 seconds but the second I open my door to get out it shuts off. I have my headlight switch on auto at all times and tried setting it to the manual headlights all the way to the right and I think it kind of helped but they didn't stay on for 60 seconds. Is there a trick to this?
      12-28-2018, 09:49 PM   #2
drjolokia
134
Drives: 2019 M550i
Aren't the comfort lights the lights that shine down from the door handles?
      12-28-2018, 10:03 PM   #3
ksoze
ksoze's Avatar
Drives: 2018 M550iX
It's "Pathway Lighting". Need to put on high beams as exiting car.
Headlight courtesy delay feature
General information
The low beams stay lit for a particular time if the high beams are switched on after standby state is switched on.
Setting the duration
Via iDrive:
"My Vehicle"
"Vehicle settings"
"Lighting"
"Exterior lighting"
"Pathway lighting"
Select the desired setting.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
clee1982797.50
      12-29-2018, 12:57 AM   #4
Mach550
Mach550's Avatar
Drives: 2019 M550i
Was sure what it was called and I was leaving work in a rush.
General information
Via iDrive:
"My Vehicle"
"Vehicle settings"
"Lighting"
"Exterior lighting"
"Pathway lighting"
So if I want to keep the headlights on I have to remember to turn on the brights? There's gotta be a way to code that this isn't necessary. If the setting is on in the menu it should be automatic.
      12-29-2018, 03:16 AM   #5
Beemerguy530
United Kingdom
16
Drives: BMW G30 530D
They use to be called Follow Me Home lights. On the previous BMWs you would pull the high beam headlight stalk towards you to activate. In the G30 it's now the opposite and you push stalk forward as if manually putting high beams on.
Appreciate 2
clee1982797.50
      12-31-2018, 11:22 AM   #6
530iDriver
530iDriver's Avatar
Drives: 2017 BMW 530i
General information
Via iDrive:
"My Vehicle"
"Vehicle settings"
"Lighting"
"Exterior lighting"
"Pathway lighting"
That may be it however to enable the follow me home timed function of the headlights you have to pull enable the high beams from the left stalk even if you have the time out specified and the headlight switch set to Auto.
You have to pull the stalk towards you to enable follow me home.
This is the way it has work in every BMW product I have owned going back 15+ years.
Personally, I would hate to have the headlights stay on every time I exit the car.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness....
      12-31-2018, 02:18 PM   #7
Mach550
Mach550's Avatar
Drives: 2019 M550i
This is my first BMW so I'll just have to get used to tapping the stalk when I need them on. This is mainly for my long tandem garage when I get home at night so I don't bang my shins on something.
      12-31-2018, 08:18 PM   #8
saporitj
Drives: 2019 540ix M Sport
I think you push away from you for high beams and path lighting. The auto is nice but I prefer having to do it manually too. Now no has to remind me that you left your lights on in the middle of the day. Also you can sneak home. I don't have too.
Oh yea those settings all the way to the right are a German thing. They are for parking on the street and leaving the running lights on either side on all night. Had them on my Benz. Can be useful if car is parked in narrow street or in bad weather.
JS
      01-01-2019, 04:41 AM   #9
Beemerguy530
United Kingdom
16
General information
Via iDrive:
"My Vehicle"
"Vehicle settings"
"Lighting"
"Exterior lighting"
"Pathway lighting"
It's push stalk forward now in G30. Pull towards only flashes headlights. At least it is in UK.
      01-10-2019, 02:20 PM   #10
StuW530e
27
Drives: BMW 545e M Sport
Mine switch off when I get out of the car (switch left on auto) but I just press the unlock button and the lights come back on for 20secs, if needs be I just press unlock again and then lock it once I am through the front door. Hope that helps..
      01-15-2019, 05:46 PM   #11
timmahh
ghey
timmahh's Avatar
Drives: Viertürigen Fahrzeugs
Found this in the owners manual; sounds like you have two options, either using the headlight stalk when exiting the vehicle, or lock the doors and use the panic button:
Switching on the headlight courtesy delay feature:
Press the panic button on the remote control.
Set the duration. [in the online manual this links to the iDrive section]
Note this shouldn't activate the panic alarm. Per the manual that requires holding the panic button for three seconds or pressing the button three times in succession.
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
      01-15-2019, 06:20 PM   #12
530iDriver
530iDriver's Avatar
Yes! You are absolutely correct about the panic button. Forgot that one. Just don't keep it pressed too long else the alarm siren will trigger.
5post
