12-21-2018, 06:41 PM | #1 |
78
Rep 388
Door handle not unlocking door
On my f30 recently my door handle has not been unlocking my door randomly. The door lock seems to be going up and down slower than usual. Any one have experience with this? Will cpo cover it? Thanks
12-21-2018, 06:52 PM | #2 | |
1308
Rep 1,827
driver door will not unlock from time to time when I pull the handle https://f30.bimmerpost.com/forums/sh....php?t=1217271
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
12-21-2018, 09:54 PM | #4 |
113
Rep 338
i just went to the dealership the get this problem fixed
it's the door actuator are you still under warranty? if not, you probably would have to pay the part is not more than $100 but labor is expensive because it required you to take off the panel there's youtube DIY video available if you wanna DIY |
Astone2278.00 |
12-21-2018, 09:56 PM | #5 | |
78
Rep 388
Be taking it in to see what they say! They did say they may charge 80 if it is not covered to diagnose it. |
12-22-2018, 03:16 AM | #7 | ||
967
Rep 2,655
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
12-22-2018, 03:17 AM | #8 |
238
Rep 878
I had this and my dealer replaced both front door motors, not seen the issue since.
12-24-2018, 10:44 AM | #11 |
Just Copacetic!
178
Rep 616
Hopefully BMW has updated their door actuators, I have a 2016 F36 and a 2019 F22. The F36 has one year left on warranty.
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite '19 230i MSptPkg AlpWhite |
01-02-2019, 10:14 AM | #15 |
176
Rep 614
Drives: 2016 F36 M Sport
This just started happening on my front doors and my original warranty just expired sometime in December
Does anyone know if the fix is covered with the CPO warranty or only the original?
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
01-02-2019, 10:54 AM | #16 |
78
Rep 388
QuikSilver_175.50 |
01-24-2019, 05:12 PM | #17 |
Rep 28
What sucks is the lock actuator is either $49 or $215 based on whether you have the alarm or not... Of course my car does not and supposedly needs the $215 actuator. Has anyone else used the cheaper part in a non alarm car? Why would there be a 300% price difference?!!
01-24-2019, 06:28 PM | #18 |
981
Rep 1,560
You may not need an actuator. My driver's door won't open from the handle from time to time (with the symptoms mentioned above), but if I lock/unlock it using the central locking button on the dash the handle will work. After this happened a couple of times, I decided to put my trickle charger on my car. Once I did, the inside handle started working again. I'm thinking it is about time to replace, my 5+ year old battery.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. Last edited by COKen; 01-24-2019 at 10:54 PM.. |
01-24-2019, 07:13 PM | #19 |
2422
Rep 4,466
Drives: '23 X1 28i xDrive
There's about 100 threads on this. It's your door actuator. Mine were both replaced, but they were under original warranty, so I'm not sure about CPO. I've seen conflicting info in all those threads.
01-25-2019, 10:10 AM | #20 |
Rep 28
I'm out of warranty on my 2014 F31. Has anyone tried the cheaper actuator in a non-alarm equipped car? I still don't understand the enormous price difference for NOT having an alarm on the car.
The part numbers are 51217202146 ($49 or $66 for right and left!) for the alarm equipped car and 51217229458 ($215) for the non alarm version. |
01-25-2019, 01:57 PM | #21 |
981
Rep 1,560
If you do a bit of Googling you can find prices all over the place. I saw both for less than $100. BMW of Atlanta has both at the same price. I'm not sure what the difference between the two are, but they look very much the same to me. Where did you fine the on for $49-66? Do they not have the other one?
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
