12-19-2018, 07:49 PM | #1 |
Rep 29
check engine light came on today
First post here, and hello to your all, ready for Xmas yet?
My car is 2018 us version(Canada) 540i m sport, had the car since June 2018, Love the car, but today check engine light came on, just in time for xmas, but there's no error message in idrive at all. check the code using bimmerlink, it says: active cooling damper control (akks), blockage at all ambient temperature, blockage warm ambient temperature in initial and learning phase. Call my dealer and book the appointment after xmas. But should I be worried? anyone have same issue? Thank you very much |
12-20-2018, 03:15 AM | #2 |
185
Rep 301
I wonder if this relates to the grill shutters? If so, then if you are driving long distances then the engine might not get the right cooling so I'd be careful... I may be way off the mark with this, but that would be my guess given the code...
12-20-2018, 04:05 AM | #3 |
82
Rep 136
Drives: 2018 BMW M550i
Mine came on about a week and a half ago for the same issue. Taking it to the dealer today to get fixed - had it in Tuesday for diagnosis, but could leave the car overnight for a fix.
Can't say how much of an issue it will cause. I know my upper shutters were working fine before the diagnosis visit, but after it seems they disabled them and left them open. Haven't looked at the lower shutters to see how they were set.
________________________________________
2018 BMW M550i - Med Blue / Black / 668M wheels [ZCW, ZDA, ZDB, ZDH, ZEC, ZLS, ZPK, 416, 5DV, 6WB] (ED 9/18/2017; PCD 11/30/2018) 2009 Acura MDX Tech - Silver / Grey (2009-2017) 2003 BMW Z4 3.0i - Silver / Red (2006-2009) |
12-20-2018, 09:14 AM | #4 |
798
Rep 1,736
Drives: 2019 BMW 540i xDrive
I thought grill shutter was suppose to open when it gets hot anyway
12-20-2018, 10:17 AM | #6 |
376
Rep 1,223
May not be related, but check your gas cap to make sure you turned it to the click during last gas fill.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
12-20-2018, 06:36 PM | #7 |
Rep 29
Thank you all for the reply. Will visit my dealer right after Xmas, hopefully they can figure it out. Fingers crossed
I'll report the results Again thank you all for replying |
12-21-2018, 08:22 AM | #8 |
3086
Rep 4,210
I think the important thing, which you did, was to report it to the dealership and make an appointment. If continued driving could cause a problem, you should be protected under the warranty as the dealership would/should have told you to stop driving if that was necessary.
12-21-2018, 08:29 AM | #9 |
1708
Rep 2,539
I bet your automatic front grille shutters are stuck in the open position. That can trigger a check engine light. Only solution is to replace the shutters under warranty.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness.... |
01-23-2019, 07:49 PM | #10 | |
Rep 3
I found it interesting that the tech's write-up said that neither the upper nor the lower flaps moved, but only the lower flaps needed to be replaced in order for both flaps to move. If anyone cares to know, the PN is 51-13-7-497-285. jD |
clee1982797.50 |
01-23-2019, 07:55 PM | #11 | |
82
Rep 136
01-23-2019, 08:18 PM | #12 | ||
1708
Rep 2,539
01-24-2019, 07:44 AM | #13 |
687
Rep 663
When I first found out about these "shutters," I was thinking that this is a classic example of over-engineering something. It's just another thing that could go wrong.
I am still moving forward with my order, so it's not a deal breaker, but I do think it's excessive, and unnecessary. My 2 cents.
2019 540i | Black Sapphire | Black Dakota Leather with Blue Stitching | M Sport Package | Executive Tier | Driver Assistance | Parking Assistance | HK | M Sport Brakes | Leather Dashboard
2016 M3 | YMB | Black Extended Merino | CF Roof | CF Trim | DCT | Adaptive | Executive |
07-29-2020, 11:48 AM | #14 |
Rep 2
Drives: 2018 BMW 540i Xdrive (M)
This again!?
Had my fancy over-engineered electric shutters replaced under warranty last year (one year into my lease) and they decided to stop working again today. Check engine light is on and they do shut but only 15-20 minutes after the car is off. I wish they could be manually set to open, the only time they are relevant is to preserve engine heat when the car is turned off in cold weather (and I park in the garage year-round). I’ll be making an appointment... Again.
08-04-2020, 04:20 AM | #15 |
181
Rep 359
I´ve had my new (to me) MY19 G31 for four days now, and the Check Engine light came on this morning. I assume it´s the shutters. My dealer is busy due to holiday season, so it´s booked in in CW35...
´22 iX3 M Sport "Charged" - Cashmere Silver
´22 Mini Cooper SE "Yours Trim" - Island Blue |
rellascout71.00 |
08-10-2020, 10:38 AM | #16 |
181
Rep 359
Not that it seems like anyone cares at all, but it was a faulty NOx sensor, which was replaced under warranty. Car got a full softwareupdate as well; not that I can see any difference.
Check Engine light went out Friday, but there must have been some codes stored anyway. |
