12-19-2018, 02:46 PM | #1 |
BimmerPost Supporting Vendor
3847
Rep 54,376
Drives: F80 M3
Ferodo DS2500 F87 M2 Competition Track/Street Brake Pads
The DS2500 is currently the best hybrid track/street pad on the market. It features the moderately high bite and solid fade resistance of a track pad, with the relatively low dust and noise levels of a street pad. When used as a street pad, it can produce some squeal on certain vehicle platforms. During aggressive driving the DS2500 is known for its flat torque curve, which means as temperatures go up, the response through the brake pedal remains consistent. If you drive aggressively on the street, do some canyon runs, autoX, and maybe some light track duty on street tires, the DS2500 is tough to beat.
When used on fast, heavy cars on the track with race tires, pad wear rates tend to be higher than some of the full track pad compounds. Under those conditions, Essex would recommend the Ferodo DS3000 or DS1.11. Front and rear set $957 Order here: https://hpautosport.com/product/fero...00-brake-pads/ Last edited by HP Autosport; 07-13-2023 at 08:10 PM.. |
12-27-2018, 10:41 AM | #2 |
3847
Rep 54,376
Drives: F80 M3
Hybrid Street/Track pads for your M2C
12-31-2018, 03:33 PM | #3 |
3847
Rep 54,376
Drives: F80 M3
One of the best Hybrid street/track pads available for your M2 Competition
