12-17-2018, 09:47 AM | #1 |
30
Rep 47
Has anyone spotted rust on any of their doors, I have a 2018 M550 and every door is rusting on the bottom edges, it looks like it is along the welding bead. I'm a little distraught as the car has 3,400 miles on it and I always wipe out the door jambs and it gets waxed monthly. It just got dropped off at the dealership this AM so waiting to hear what's going to happen. Just wondering if this a isolated problem or common. Thanks!
12-17-2018, 12:48 PM | #3 |
89
Rep 124
Drives: BMW M3 ZCP 2017, 540ix 18 G31
You are sure you’re not confusing a brown residue for the glue? On the bottom of both my f80 and g30 doors I have visible yellow/brown glue residue. Not pretty but quite far from rust.
I’d be shocked if a g30 is rusting already.. Pictures would help |
12-17-2018, 12:56 PM | #4 |
30
Rep 47
I will post pics (dealer has car) when I can, definitely rust, it's on the outside and it has pitted areas on both back doors.
12-17-2018, 12:59 PM | #5 | |
89
Rep 124
I await pics with great interest. If a g30 is rusting in Texas already, then this doesn’t bode well for Swedish salty and icy winters... |
12-17-2018, 01:07 PM | #6 |
30
Rep 47
That's what I thought, but it has crept up to the size of a dime on one door you can see it standing outside the car directly above rocker panel, and pitted the rear doors on the edge as it curves up near the wheel well. Will post photos asap
12-17-2018, 02:20 PM | #7 | |
798
Rep 1,736
Drives: 2019 BMW 540i xDrive
apiccus3.00 |
12-17-2018, 04:20 PM | #8 |
89
Rep 124
Just checking: the car was/is brand new? There have not been any botched bodywork repairs?
12-17-2018, 04:32 PM | #9 |
321
Rep 721
Drives: 2018 530e
He did even before posting here, thats why he says in his post that he just dropped off his car with the dealer.
2018 BMW 530e Alpine White | Black Napa Leather | Bone Stock
12-18-2018, 02:11 AM | #10 | |
89
Rep 124
At least this is what the warranty looks like in Sweden. This may of course be different in other countries. When I spoke to my dealer he agreed that in practice it was worthless. But I’d presume that rust on a new high end BMW produced in 2018 is something that both the dealer and BMW would consider shocking and highly out of the ordinary and try to remedy ASAP and without any hassle or publicity. Worries me though, cause I had plans to keep the car at least five years or so., Still, too early on to draw conclusions. I guess we await pictures |
clee1982797.50 |
12-18-2018, 03:07 AM | #11 |
2782
Rep 5,095
Yes will be interesting.
I'm no expert but thought aluminium could not rust although I thought it could oxidise which I thought was a whiteish colour? Any experts here confirm! It's not wax used to protect it whilst being delivered that wasn't removed as part of the pdi possibly? |
12-19-2018, 06:06 AM | #13 | |
56
Rep 225
The red/brown colour of rust is caused by the oxidation of iron. Steel is an alloy of iron. (Stainless steel contains chromium which forms an oxide a bit like aluminium and it is this oxide which makes stainless steel so rust-resistant). So if the OP genuinely does have rust on his car's doors, the doors are made of steel, not aluminium. |
12-19-2018, 07:46 AM | #14 |
89
Rep 124
Do we know for certain that the doors on the g30 are from aluminium? Does the same apply for the g31 as well? Are we talking about all doors or just the fronts?
12-19-2018, 07:55 AM | #15 |
30
Rep 47
Zap-xpilot88.50 |
12-19-2018, 07:59 AM | #16 |
30
Rep 47
I am traveling this week, I hope to have answers on Friday, the service advisor called me yesterday saying some of the discoloring is from a sealant BMW uses to prevent rust and corrosion, and has been cleaned, but he said they also have found some abnormalities on the edges of the rear doors. I will update this on Friday (hopefully).
12-19-2018, 08:00 AM | #17 | |
Plenipotentiary
2614
Rep 3,046
Is it basically like this on the outside and oozing out from the weep holes on the bottom corners of the door panels? |
12-19-2018, 09:52 AM | #18 | ||
30
Rep 47
12-19-2018, 10:43 AM | #19 | |||
Plenipotentiary
2614
Rep 3,046
Who washes the car, how often, and is the water source exceptionally hard? Have you driven it on winter treated roads? Both can leave heavy mineral deposits in a short amount of time. Mix in some brown cosmoline, brake dust, and good old dirt, and it can get funky. |
12-19-2018, 11:01 AM | #20 |
644
Rep 629
I have seen that sort of discoloration on many BMWs over the years and I think it comes from lubrication used on the door hinges. Don't think it is rust for a couple reasons posted here, but I could be wrong. Have you had your car in for service since you bought it? The techs may be lubricating the hinges each time. --Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
LetsrollM55030.00 |
12-19-2018, 11:09 AM | #21 | |
Plenipotentiary
2614
Rep 3,046
The cars are covered in it prior to the ocean voyage and it gets everywhere. |
12-19-2018, 11:12 AM | #22 |
103
Rep 231
You can try the magnet test. The magnet will be attracted to iron and steel, but not aluminum. Just be careful, place something soft between your magnet the the paint.
If there is any steel inside the door and if it is rusting, you probably wouldn't see any signs on the outside for a car this new. |
LetsrollM55030.00 clee1982797.50 |
