07-14-2008, 02:42 PM | #1 |
597
Rep 5,448
is your oil pan drain plug exposed? like this?
I was expecting to see the pan have some cover over this area. or did the dealer leave them off?
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
07-14-2008, 07:59 PM | #5 | |
374
Rep 8,033
Actually, he is asking if there should be more cover, like a panel or something, under the engine, around the oil drain.
07-14-2008, 09:55 PM | #6 |
Commander-In-Chief
2107
Rep 8,913
Yep, E46 had a plastic plug there. Mine is open like the others.
07-14-2008, 09:58 PM | #7 |
597
Rep 5,448
i am referring to the small circle opening above and larger ovalish opening below the black jack point. they are both open and expose the plugs. the e46 and S4 Ihad were totally covered.
07-14-2008, 09:59 PM | #8 |
597
Rep 5,448
thanks greg- is the large opening the oil drain plug? whats the small opening plug for?
Greg do you have an exploded parts view on the air filter intake and its related parts, snorkel, silencer etc?
07-14-2008, 10:19 PM | #9 | |
Commander-In-Chief
2107
Rep 8,913
Under engine panel openings
"The E92 M3, just like the E46 M3, is equipped with a reinforcement plate, known as the thrust panel, made from aluminium alloy. The thrust panel primarily increases the torsional strength while also acting as a lower motor cover and oil pan protection. The thrust panel is fitted to the axle carrier with six bolts from below, and has two openings for changing the oil."
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 07-14-2008 at 10:43 PM.. |
07-14-2008, 10:33 PM | #10 |
125
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
Greg, that was above and beyond the call of duty.
I vote you Forum Member of the Month. Thanks. Is that a torx oil plug?
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
07-14-2008, 10:35 PM | #11 |
Commander-In-Chief
2107
Rep 8,913
Of course.
07-15-2008, 10:28 AM | #13 |
597
Rep 5,448
awesome Greg - thanks!
so for DIY oil change you have to drain both?
07-15-2008, 11:33 AM | #14 |
123
Rep 1,973
The tech did both when I took my car in at 1200.
MDCT ... so you can drive and eat a hamburger at the same time. |
07-15-2008, 11:36 AM | #15 |
Commander-In-Chief
2107
Rep 8,913
2 oil drains
Yes, you obviously need to do both, since there are two low points. I'm not sure how the S54 got away with just one.
07-15-2008, 02:49 PM | #16 |
597
Rep 5,448
looks like water in at point 1 would drain out at point 3?
07-15-2008, 03:46 PM | #19 |
Commander-In-Chief
2107
Rep 8,913
Yes, and there are also drain flaps directly under the hood vent.
