BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    BBS FI-R interest thread...poll
View Poll Results: which size would you opt for.
20 inch fitment (OEM) 57 51.35%
21 inch fitment 54 48.65%
Voters: 111. You may not vote on this poll
      12-04-2018, 11:27 AM   #1
Ragazzi-07
Ragazzi-07's Avatar
250
Drives: 2018 M5
Hello All
this is an interest thread merely for the purpose of seeing how many f90 M5 owners would like to own a set of the iconic FI-R wheels
i gave 2 options 20inch oem fitment or 21inch fitment.
If we gather enough interest BBS "may" look at doing this fitment.
I have enclosed some pics for reference. thanks IND
FloridaM5586.50
      12-04-2018, 12:44 PM   #2
brad850csi
1318
Drives: 16 F13 M6 Comp
Best wheels out there - would like to see an option for 20" front and 21" rear too.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
      12-05-2018, 10:30 AM   #3
Ragazzi-07
Ragazzi-07's Avatar
250
Drives: 2018 M5
keep them coming guys....i will be emailing my contact at BBS if we have enough interest.
      12-05-2018, 01:27 PM   #4
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Are you saying front 20" and rear 21"????
You can't do that on this car!!!
Life is too short...enjoy your life
///M
      12-05-2018, 01:43 PM   #5
brad850csi
1318
Sure you can. BMW allow you to do square tyres as well as one of the options being 265/40r19 with 285/40r19.
So from identical circumference front and rear up to 2.3% bigger at the rear.
Running 275/35r20 and 295/30r21 is only 1.4% different and 275/35r20 and 305/30r21 is 2.2% different
      12-05-2018, 02:15 PM   #6
Miko M
///M
Miko M's Avatar
265 front and 285 back is 2.6%. NOT 2.3%
Didn't know we have that size, all I know is 275 front and 285 back which is 1.1 %
Bmw recommendation is 1.3% or less
Obviously less is better.
Rim width doesn't effect the rolling diameter much but, you can't stretch the tire to much.
This is old article from BMW :
"The tire circumference can fluctuate up to 1% or more as a result of mixed tires or wear. The tire tolerance logic decides depending on the driver's command and driving situation whether the slip is to occur in the transfer case clutch or at the contact area between tire and road.
If the slip is permitted in the transfer case clutch, the locking pressure set by the pre-con- trol is reduced in order to keep the work loss low. In the driving dynamic control situation, the clutch is locked slightly more than normal, the four wheel drive is always guaranteed when required.
For maximum xDrive performance, tires (and wheels) of the same diameter should be installed on the vehicle."
///M
      12-05-2018, 02:22 PM   #7
brad850csi
1318
Here is where the 265 and 285 combo is documented:
https://www.realoem.com/bmw/enUS/sho...diagId=36_2297
I was doing 27.98" / 27.35" = 1.023035 for the 265 and 285 option
Then for my 21" concept, 28.21" / 27.58" = 1.022843
      12-05-2018, 03:02 PM   #8
Miko M
///M
Miko M's Avatar
Looking at the website on mine phone it looks like 265 or 285 not 265/285 unless I am seeing things different. Need to go on computer and look at the website.
Your first option would be acceptable, second one IMO not so much.
Any AWD manufacturers ( like Subaru ) don't recommend to go over 1% they are pioneers in AWD
I personally like to stay below 1.3% to be safe
///M
      12-05-2018, 08:57 PM   #9
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Interesting that there are more 21" wheels selected via the poll.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      12-06-2018, 01:58 PM   #10
Ragazzi-07
Ragazzi-07's Avatar
250
Drives: 2018 M5
21's do suit the car, but 20's with the right tire and drop will be fine.
i opt for 20's due to lower height and road conditions etc.
      12-10-2018, 02:37 PM   #11
Ragazzi-07
Ragazzi-07's Avatar
250
Drives: 2018 M5
Bump
      12-11-2018, 12:25 PM   #12
Jman911TTS
69
Drives: A few toys
Im down for a set in 20
19 Model S Dual Motor
18 M5 - 18 M3CS
18 911 Turbo
19 Tacoma TRD Pro
20 Supra
      12-11-2018, 04:40 PM   #13
marcvtec
413
Drives: M5
They better hurry - come april i need some new shoes
      12-13-2018, 11:41 AM   #14
strettyend
85
Drives: 991 GT3 / F90 M5
My GOD that M4 looks good. I'm interested...
2018 F90 M5 - Donington Grey
2014 991 GT3 - Mexico Blue
      12-13-2018, 12:37 PM   #15
Ragazzi-07
Ragazzi-07's Avatar
250
Drives: 2018 M5
keep the responses coming boys.
the more interested garnered the more likely BBS is to build these wheels.
      12-15-2018, 12:40 AM   #16
Spoolin Montego
Spoolin Montego's Avatar
666
Drives: 16 m3/20 x5m/23 m3
F90 needs 21s. Just got a comp and the 20s honestly look small for the wheel well
      12-17-2018, 12:33 PM   #17
Ragazzi-07
Ragazzi-07's Avatar
250
Drives: 2018 M5
waiting to hear back.
sit tight....
      12-17-2018, 10:10 PM   #18
josec70
josec70's Avatar
^^^this^^^^
      12-18-2018, 11:04 AM   #19
Ragazzi-07
Ragazzi-07's Avatar
250
Drives: 2018 M5
i guess it also depends on the drop. have a look at this car sitting on 20 inch BBS LM's from another member. i think it looks perfect!
      12-18-2018, 02:11 PM   #20
josec70
josec70's Avatar
Attachment 1956677
The drop will be unaffected whether you go 20" or 21" as the overall width of the wheels/ tires will be very similar; it's really dependent on the suspension set-up.
Aesthetically speaking, I like the look of a larger wheel better, in this case 21". This is 100% subjective and based solely on my preferences.
      12-20-2018, 08:49 PM   #21
Who's on first
Who's on first's Avatar
Drives: A-10C
Interested in 20's
      12-21-2018, 12:22 AM   #22
Ragazzi-07
Ragazzi-07's Avatar
250
Drives: 2018 M5
Good news boys.
Top brass mentioned to me this is marked "heavy consideration" at the next meeting in the new year!
We're moving in the right direction.
Considering it was a "no" before.
I've sent a copy of this thread to them as well.
Keep the votes rolling in 😬
Copyright ©2000 - 2025, vBulletin Solutions Inc.
