11-30-2018, 08:02 PM | #1 |
29
Rep 63
Driver's Seat Moves/Pops
Hi all,
I have a 2018 M550ix with the multi-contour seats and they have been great for the first 10 months I've owned the car. But in the last few months I've noticed that the driver's seat, when I accelerate the car from a stop, seems to move ever so slightly, causing a popping sound that can be heard and felt. I can mimic it when the car is at a full stop by leaning back into the backrest. Sometimes the pop is subtle, other times it is really bad. The weird thing is it will sometimes go away, particularly if I have just moved the seat bottom up or down electronically. But it will start up again after driving for a bit. Other times it will be doing it like crazy, and then, without moving the seat electronically in any way, when I start up the car again 5 hours later or so, the problem disappears. No more popping. But it always comes back. Anyhow, as you can imagine, it is super annoying to have the seat pop whenever I accelerate the car from a stop. Took it into the dealer and they said this is normal, and that a few others cars on the lot are doing the same thing. Has anyone else experienced this? Did a search on the forums to see if anyone had a similar problem, but couldn't find anything. Thanks. |
12-01-2018, 05:17 AM | #5 |
2782
Rep 5,095
I've got say that having been reading these forums for a number of years I'm getting the perception that some of the dealers in the US are below par in respect of addressing issues. As I say just a perception for me.
I would certainly not accept their answer and push to get it resolved |
12-02-2018, 11:23 AM | #6 | |
644
Rep 629
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
12-02-2018, 12:27 PM | #8 |
281
Rep 531
It's under warranty so you can always go to another BMW dealer. Shouldn't be a issue except when it comes to loaner car. Some dealerships don't care if you bought it from them and will give you a loaner.
JS
12-02-2018, 06:15 PM | #9 |
29
Rep 63
Thanks all.
So I got the car back from the dealership, and it wasn't exhibiting the problem for about 24 hours, but now it is back in full swing. I was able to narrow down the problem a bit more today. I realized that the noise happens when the seat bottom cushion moves up and down slightly. Leaning back into the seat, either while sitting still, or because of acceleration, was a misleading trigger. Although the popping noise comes from doing that, it is actually because those movements lead my butt to push down harder on the seat. I was able to sit in my car parked today and with my hands on the front of the seat cushion pull it up and down, without leaning into the backrest in anyway, and cause the movement and popping. This explains why the noise will go away for a bit if I electronically move the seat up or down, but not if I move the seat in other ways. Needless to say, I have no idea what they meant when they said that other cars on the lot were doing this too. I'll be chatting with my SA tomorrow and hope to sort this out. EDIT: Just went back in the car and I can get it to happen just by lightly lifting my butt up and down on the seat while seated with the car stopped. I can feel the seat bottom moving slightly. Hopefully, these revelations will lead to a solution. Last edited by LexProf; 12-02-2018 at 06:35 PM.. |
clee1982797.50 |
12-10-2018, 12:58 PM | #10 |
Rep 6
I had the same problem with the driver's seat on my M550i. Took it into the dealer and was able to reproduce the problem on a test drive with the shop foreman. They gave me a loaner, and two days later, I got my car back, and the problem is fixed: They replaced some parts of the seat mechanism.
Regards, Otis |
12-10-2018, 04:58 PM | #11 | |
26
Rep 68
12-11-2018, 02:26 AM | #12 |
29
Rep 63
Thanks guys. If you have any more detail on what was replaced (like a part number from the work order), I'd greatly appreciate it. I'm going in tomorrow and am slated to chat with the shop foreman. I can easily reproduce it now, even when the car is at a stop, and even when the car has been sitting for hours. Just moving my butt up and down causes the problem. Hopefully, we will sort it out soon.
12-14-2018, 01:26 AM | #13 |
1652
Rep 2,402
Yep, same here.....had the same sound and they replaced the seat frame (do not have service receipt that has part number but it was definitely described as the seat frame) under warranty. This is a common issue with the G30. No issues after they replaced the frame.
If I remember correctly.....they may have tried to lubricate it when I first complained. I don't think it helped much so I took it back when my next service was due and that is when they replaced the frame.
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
12-14-2018, 11:50 AM | #14 |
129
Rep 276
I have an '18 X3 that exhibited the same problem you describe. The dealership told me that it was a cable in the seat which was popping in/out of its clip. They rerouted/secured it better and the problem went away
While it may not be the problem you have, or the same car - I figured it's something to consider as well |
12-15-2018, 07:26 PM | #15 |
29
Rep 63
Success! Took it in, the shop foreman verified the problem, and later found a faulty seat frame. They ended up replacing the seat frame (part 52-10-7-367-545) and putting in 5 new rivets. So far, after driving the car for a few days, no problems. Hopefully, that will take care of the problem for the life of the car. Thanks again to everyone for your input. Back to loving my car now....
Best, LexProf Last edited by LexProf; 12-17-2018 at 01:14 PM.. |
12-17-2018, 10:10 AM | #16 |
17
Rep 120
Got same problem! Will try to claim it with my dealer next time... very annoying...
Honda Accord -> Subaru STi -> E93 -> F30 + F15 -> F30 -> F31 LCI -> G31
12-17-2018, 01:15 PM | #17 |
29
Rep 63
What a weird thing to go wrong with this car. I only weigh 170lbs and my car only had about 5,000 miles when the problem first appeared. The fact other people are experiencing this problem suggests something went wrong with the manufacturing process for some frames.
11-04-2022, 01:25 PM | #18 |
14
Rep 35
Drives: G30
Should have asked BEFORE I loosened them... kinda urgent; does someone know the torque spec for the driver seat bolts?
Wave upon wave of demented avengers march cheerfully out of obscurity into the dream. -pf
11-05-2022, 02:49 PM | #19 | |
25
Rep 71
It’s also didn’t resolve my issue of the back rest creaking. |
742002tii13.50 |
